Looking for a source of cheaper leaf springs
Old Aug 28, 2006 | 06:53 PM
junkyardblacksmith's Avatar
*Post removed by user
Last edited by junkyardblacksmith; May 2, 2007 at 02:35 PM. Reason: Closing account
Old Aug 28, 2006 | 07:14 PM
truckmike26's Avatar
Have you looked through the yellow pages for local spring shops? Check around.
S-10? Toyota? Different prices? Will I be the only one to smack the obvious button?
Old Aug 28, 2006 | 07:21 PM
BLKNBLU's Avatar
http://www.downeyoff-road.com/home.html
Try this. They don't have prices on their site anymore but when I got mine they were $186 for the pair. Check with member SoCal80, as he just recently purchased some and should have more current pricing. Also wondering about your online name, if you can weld/fab consider a Chevy spring swap. You will want junkyard Chevy leaves for cheap and some hangers and odds and ends. But that will lift the rear end probably higher than you want, requiring some attention to the front to keep things even.
Old Aug 28, 2006 | 07:23 PM
I've called a few places. Most of them are more expensive.
Please help me understand why I am having to pay double the cost for somthing almost exactly the same as far as I can tell.
His springs were made by the same company with the same material, and are close to the same dimensions as the replacement Toy's springs.
Unless I am missing something incredibly obvious, it just seems like gouging on the surface.
Old Aug 28, 2006 | 07:26 PM
Thanks for the link. $186 is a hell of a lot better than $290. But I don't need the lift.
I am pretty handy with a welder and torch, and I have considered a swap, but after further consideration I feel it is more trouble than it's worth in my situation.
There is such a huge market for high performance 4x4 toyota parts out there, it's difficult to find budget stuff that will just do the job under normal conditions.
Old Aug 28, 2006 | 07:34 PM
BLKNBLU's Avatar
Yeah. Kinda got that from your original post that you might be just trying to solve your current issue... not start a whole new project. IIRC the chevy's lift the rear 4 or more inches. Some will pooh-pooh the Downey's but hey, they do the job.
Old Aug 28, 2006 | 07:36 PM
I just meant the difference in price is just supply and demand -- many more S-10s than Toyotas. Despite the problems we have with our trucks, I can't imagine owning/paying for/fixing an S-10. Brrrrr!
Old Aug 28, 2006 | 07:39 PM
BLKNBLU's Avatar
Hmm... Just actually looked at the Downey site and prices are listed again. Sorry. $199 now. Still beats $290.
Old Aug 28, 2006 | 07:41 PM
Good point.
Old Aug 29, 2006 | 03:44 AM
tulsa_97SR5's Avatar
might try http://car-part.com/ to see if you can find anything better in a junkyard nearby - they seem to go for about 50 a side, but who knows if they'll have any more arch than you do now.
Old Aug 29, 2006 | 03:49 AM
Intrepid's Avatar
Why not just go get two rear packs from a junkyard and build your own single 4-5 leaf set? I mean, you want cheap and you don't want any lift...
Old Aug 29, 2006 | 05:22 AM
trythis's Avatar
what about getting yours rebent at a spring shop?
Old Aug 29, 2006 | 06:28 AM
rockota's Avatar
I don't think you'll be happy with an attempt at re-arching them - it usually fails after a short period of time.
The Downey rear springs are pretty crappy and settle fast. I bought some 3" rears in 95 and they settled to 1.5-2" pretty quickly. So fast that I had to throw longer shackles at the truck to level it with the 3" IFS rancho kit I was running. See if you can get their 2" rears still and go that route. If the truck has a slight rake for a bit, know that it will go away. If you want, you can also throw some ball joing spacers at it or crank up the torsions a tad (1/2-1" max) to level it. That's the route I'd go.
Old Aug 29, 2006 | 07:12 AM
No, I have never been satisfied with rebending. They are especially bad about flattening if you use your truck for heavy loads like I do. I don't think they are so bad if you just use your truck for no load off roading though.
Old Aug 29, 2006 | 07:32 AM
4Crawler's Avatar
x2 on adding some more leaves from another spring pack. Once you lift the rest of the spring leaves off of the stiff overload leaf, the ride will be much better. I run a 2 sets of stock rear leaves on the front of my '85 and they are awesome:
- http://www.4crawler.com/4x4/4R_suspe...#CustomSprings
Cost? About $20 for a new set of poly bushings for the springs and a pair of longer center bolts.
Old Aug 30, 2006 | 06:16 PM
Rather Diesel's Avatar
You mentioned heavy loads. This is the route I'm going with the stock rear springs.
http://www.truckspring.com/firestone...rear-2116.html
punks_is_4x4
May 31, 2016 06:03 AM
Scottcrb
Mar 3, 2016 11:57 AM
RickyD
Oct 2, 2015 07:53 AM
justdifferentials
Sep 5, 2015 06:52 PM
