Skyjacker springs for sas
Old Sep 9, 2015 | 11:35 AM
RickyD's Avatar
I've searched around and haven't found any info on the subject and haven't found much so I figured I'd ask you guys. I'm doing a sas on my 89 pickup and want to use 7" skyjacker springs for an 85. Has anyone used these? The guy at SKY said it won't work with his hanger kit because the springs are shorter than sas springs but I figured I would see if you any of you guys have had success running this setup
Old Sep 10, 2015 | 10:43 PM
RickyD's Avatar
Anyone?
Old Sep 11, 2015 | 12:35 AM
dropzone's Avatar
Fossilized
not a whole lot of people go that high, 7" will have quite a bit of arch.
the sky jacker springs are designed to go on a stock 79-85 truck.
Old Sep 11, 2015 | 01:40 AM
muddpigg's Avatar
If I were you I'd research articles on springs.
What are you building truck for??
Old Sep 11, 2015 | 12:45 PM
RickyD's Avatar
I'm not exactly too worried about the arch. The truck is mostly in the mud. I was more worried about the length of the springs. I know most solid axle swap springs are about 47" long while most of sfa lift springs are about 44 " long. I'm worried about them being too short to work with my hanger and shackles. I'm wondering if someone has used sfa front lift sprigs on a sas truck without problems
Old Oct 1, 2015 | 10:22 AM
MSR's Avatar
MSR
yes it will work fine but you will need to use stock 85 shackles. NOT the sas kit shackles
Old Oct 2, 2015 | 07:53 AM
RickyD's Avatar
Thanks for finally getting some input! I'm running boomerang shackles so hopefully those will work. Not standard sas shackles. I'm mount my front hanger flush with my crossmember as well so hopefully everything should settle correctly and the axle will be positioned in the right spot
punks_is_4x4
May 31, 2016 06:03 AM
Yotav6power
16
Mar 4, 2016 07:45 AM
voiddweller
53
Feb 1, 2016 05:46 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
Flying91
Sep 10, 2015 03:41 PM
