weird timing issue
Old Aug 28, 2006 | 11:40 AM
surfcaster's Avatar
weird timing issue
Went to check my timing the other eve . so i marked the notch, which was in the wrong place, jumpered the diag box, hooked up timing light and the notch is moving counterclockwise slowly like the timing is being retarded constantly or something. Goes all the way around and comes up on the other side and keeps moving. Could it be a bad plug or an engine knock issue? I also got a code 12 but it doesnt show each time i check it. I am a little worried so I did retard the timing for safety sake. help 91 4runner 3vze
Old Aug 28, 2006 | 12:08 PM
Flash319's Avatar
Are you sure you have the light pickup on number 1 cylinder?
Old Aug 28, 2006 | 03:34 PM
surfcaster's Avatar
yes, but I will double check. Thanks for the reply
Old Aug 28, 2006 | 04:59 PM
mr toytech's Avatar
may have a bad crank pully?? ive seen it before
Old Aug 28, 2006 | 05:37 PM
surfcaster's Avatar
would bad crank pulley be a bearing? The thing is that it keeps a perfect rhythm on its way around. Rechecked to make sure I have the right wire and it is the #1 wire. Toyota wires. Thaks again
Old Aug 28, 2006 | 06:04 PM
rebult junk's Avatar
i had the same problem on my 88 runner raplaced the balncer and problem solved
Old Aug 30, 2006 | 04:49 PM
surfcaster's Avatar
thanks rj. i talked to a mech today and he said that sounded right. Does the 3vze 91 have that harmonic balancer with the rubber ring? if it is he said it was a simple job.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
