Using 4WD-low without front wheels locked?
Old Aug 28, 2006 | 10:28 AM
junkyardblacksmith's Avatar
Will it damage any part of the vehicle to use 4WD-low for extended periods without locking the front wheels?
Thanks.
Old Aug 28, 2006 | 11:19 AM
Glenn's Avatar
No, probably not. What do you mean by extended periods?
Old Aug 28, 2006 | 11:32 AM
Intrepid's Avatar
No, the front wheels just won't receive power, the cv's and the d-shaft will still spin. Although, if you need 4 low for an extended period of time, it shouldn't be a big deal to have the front tires turning right? How long is "Extended" and what would you be doing?
Old Aug 28, 2006 | 11:38 AM
Tofer's Avatar
Sponsor
i think he just ment using 2LO until 4 wheel drive is needed... i dont lock my hubs till i need them just to see how far 2wd can get me, but use 2lo for the gearing / power.
Old Aug 28, 2006 | 11:41 AM
Intrepid's Avatar
I have always wondered why people bothered with that. I figure that since it is spinning it helps to get you over smaller obstacles with less abuse on the rest of the truck. To each his own.
Old Aug 28, 2006 | 11:57 AM
ovrrdrive's Avatar
I also do it all the time...
If I need more power to pull a boat up a ramp or go up a steep hill or curb, the truck can barely get out of its own way in H2 sometimes.
I also do it if I need more control when going over said obstacles.
I seriously doubt it will hurt anything.
Old Aug 28, 2006 | 12:06 PM
4Crawler's Avatar
I also use 2L all the time, with dual cases, I have a true 2L gear using the front reduction box in low range and leave the rear case in 2WD. Just need to watch out and not give it too much gas, since you are applying over twice the load to the rear axle alone.
Old Aug 28, 2006 | 05:50 PM
bob200587's Avatar
do both of your T case sticks fit in the same space as stock, or do you have to take the console off?
Old Aug 28, 2006 | 06:00 PM
4Crawler's Avatar
Currently the rear shifter comes out of the front recess on the center console:
Shortly I'll be installing a triple stick shifter that will bring all the shifters to the front location and there will be 3 separate, single-function sticks, Rear H-L, Front H-L, 2-4. At that point the rear shifter hole will be covered and a console could be left intact.
Old Aug 28, 2006 | 06:20 PM
This is exactly what I use this for. Helps pull heavy trailers up hills, and keeps me from having to burn up the brakes going down really steep hills under extra heavy loads. Just wanted to make sure I wasn't tearing somthing up.
Old Aug 28, 2006 | 06:23 PM
Well.. there is no 2W-Lo marked on my transfer shifter.. just 2WD-Hi, 4WD-Hi, and 4WD-Lo.
I was just asking if it's alright to use 4WD-Lo without the hubs locked to simulate a 2WD-Lo gear.
Old Aug 28, 2006 | 06:25 PM
By extended periods, I mean more than a few minutes. So far I have used this for less than 5 minutes at a time with no damage.
Old Aug 28, 2006 | 06:53 PM
Glenn's Avatar
No problem with that at all.
Old Aug 28, 2006 | 07:06 PM
mike_d's Avatar
it's no problem. it doesn't hurt anything.
here's another thread that asked the same question:
https://www.yotatech.com/forums/f2/its-bad-drive-4l-hubs-free-62590/
Old Aug 28, 2006 | 09:32 PM
bob200587's Avatar
I forgot about that little cup thing there. I dunno, when you get the other setup going I'd like to see. I know how useful the dual or trip cases can be.
Old Aug 29, 2006 | 07:40 AM
4Crawler's Avatar
Here is the prototype triple stick shifter:
Need to shorten the width of the shift rods in to the width of the blocks to ease installation. As is, will fit but requires lowering the t-case or raising the body for installation. Stock shifter is used up front with a new stick on each side of it for the two halves of the rear case. Totally sealed and should be as quiet as the stock shifter. In fact the shifter is so tightly sealed, will need to add venting to it (stock unit vents through the stick), that is the right angle fitting on the rear (white) shifter base).
Old Aug 29, 2006 | 04:11 PM
bob200587's Avatar
sweet...
Jun 1, 2021 01:51 PM
94whiterunner
9
Sep 22, 2015 07:28 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
AaronM
Jul 8, 2015 07:15 PM
skoti89
Jul 6, 2015 07:45 PM
