Converting EFI to a Carburetor
Old Sep 5, 2006 | 07:22 PM
cweich's Avatar
Question Converting EFI to a Carburetor
Hello, i am new to site and was told maybe i could get some help from you guys. I am working on a 1987 yota pickup with a 22re engine. It currently is a 5 speed, however i am converting to a 1986 automatic. I am only using the running gear out of the truck, so please keep that in mind with my wiring questions. I would like to make this bare bones, i want to remove the efi and put a carb on it. What all has to be changed, Intake for sure, but will the head, distributor and coil work?
And then to complicate things i am adding the automatic trans to the equation, if i do away with the efi, i will remove the computer, but my auto trans has alot of wires coming from it, I am assuming being an 1986 its an overdrive, will the trans work with out a computer? I thank you guys in advance for the help with this project.
Old Sep 5, 2006 | 07:57 PM
snap-on's Avatar
AFAIK no.
the trans computer needs "lots" of imputs that im fairly shure are hosed if you dump the EFI system (ie TPS, speed sensor, and who knows what else)
Your in for a nighmare if you ask me.
Old Sep 6, 2006 | 04:32 AM
Yoda's Avatar
You would need a dist & coil/ignitor from a carb engine. Try to find a manual trans. Prob cost you more to try to get an auto to work than to buy a stick.
Old Sep 6, 2006 | 04:33 AM
Flash319's Avatar
I am not sure about the trans but you will need a carb intake and the carb distributor. Then you should be good. You may be able to buy a box that will run the trans but I don't know why you would want to auto anyway. It makes the 22re a dog...
Old Sep 6, 2006 | 05:12 AM
AH64ID's Avatar
Your going to make a gutless truck even more gutless....
Old Sep 6, 2006 | 07:55 AM
cweich's Avatar
Auto Trans
Ok, so will the trans work at all with out the computer??? is there a different auto trans that could be recommended to me?? I want to stay automatic if i can.
Old Sep 6, 2006 | 07:57 AM
cweich's Avatar
EFI Question
OK, so doing away with the EFI is fairly easy, but if i run the auto trans that requires the computer, what can i eliminate from the efi that does not really need to be there, this truck will be off road only, i want to simplify thing if this is possible. Thanks
Old Sep 6, 2006 | 09:03 AM
04 Rocko Taco's Avatar
Now that I got a lot more info from you, this sounds like a pretty cool ride... Keep me updated on the progress!!!
Old Sep 6, 2006 | 09:04 AM
anthony1's Avatar
Off road only? you want to keep your EFI....better at an incline. I've been with too many carb jeep/yota to tell you that it's not fun waiting for them to start up again at an incline.
Old Sep 6, 2006 | 09:11 AM
snap-on's Avatar
-learn to drive a stick
-convert your 22r block to a 22re version.
while first gen EFI wasnt great i still belive its heads and tails better than a carb
my expertise is only on the 89 and above stuff so i dont have much to add for the auto behind a 22r. (if one existed)
Old Sep 6, 2006 | 09:52 AM
cweich's Avatar
I agree...I don;t think a auto existed with the 22r...i do know that 85 was the first year for the auto in the trucks
Old Sep 6, 2006 | 11:09 AM
Flash319's Avatar
There is no such thing as "removing stuff that does not need to be there". The trans most likley needs the TPS, AFM, Temperature as well as maybe a pulse from the distributor to know what and when to shift.
It may work without any wires but I would assume that it won't.
just my 2cents
Old Sep 6, 2006 | 01:56 PM
cweich's Avatar
just my 2cents
You're saying that i am fighting a loosing battle!! LOL...just my luck, thanks
Old Sep 6, 2006 | 02:22 PM
curtiswyant's Avatar
Things to consider:
carb intake manifold
fuel pump
distributor
coil
ignitor
exhaust manifold (02 sensors)
radiator/tranny cooler
shift linkage
sender/vacuum plugs in manifold/head
and so on and so forth...
There is absolutely no reason to convert from EFI to carb on these trucks! You're better off buying a complete engine or even a different truck entirely.
kawazx636
Oct 6, 2021 03:03 PM
mreagen
Oct 5, 2015 04:27 PM
the_supernerd
Oct 1, 2015 09:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
rmill05
Sep 27, 2015 01:43 PM
