- ‘93 Body damage, what to do
- 93 4Runner back window problems
- Replacement nuts and bolts
- How to tell if front diff is geared the same as the rear
- Engine swap
- Parasitic Battery Drain EFI fuze
- 89-95 cab compatibility
- 1993 Toyota pickup throttle sticking
- Made a dumb mistake and need advice
- Help finding 94 Toyota pickup cab
- 93 automatic 4x4 transfer case leak?
- Timing cover bolts 1990 22R
- 93 3vze - heater hose stuck
- Dead alternator but no light and battery dash gauge reading normal
- 90 22re coolant disappearing
- sound system on 89 toyota pickup
- brake line help
- I made a video on the Idle Air Control valve
- 22re dies won’t restart until cold
- 3vze 4runner Headgasket Questions
- Tail light running lights stuck on??
- rumbling noise - 1990 4runner 5spd 3vze
- 88 dlx crank no start please help
- Toyota RV clearance light/tail light issue
- Issues idling on its own but runs
- Yota doesn't run after frame swap
- LCE and othe crate engines
- No OD, no lock up
- Third member question
- W56 question
- 1989 Toyota 4X4 3.0 starts and dies immediately
- 1986-87 Truck Power Steering
- 3VZE Camshaft and Cylinder Head Cleanup
- 90 4RUNNER front wiper arm play
- 22RE Compression test results: 180-150-210-180
- 3.4 auto swap wiring help
- Sad to say this but im thinking about selling her):
- Unusual PCV venting setup
- What it is this plug? - '91 Xtracab 4X4 V6 5 speed
- wrong tranny rebuild ?
- ‘95 4runner stereo wiring
- Rough idle (RPM 1000 -1100)
- New engine,Is it too lean?
- 92 Pickup 1uz re gear - Highway RPM issues
- Rubber Windshield Gasket Installation
- Are the dimensions of crossmembers for 4 Runners and Pickups Different?
- What hose is this? 3.0
- Electrical anomaly intermittently causing no start condition - also first post
- STOLEN!!! San Diego CA - 1995 4runner - Precious Lost
- 22re dies while driving but restarts fine soon after. HELP!
- 86 4runner 4low smoke and high rpm stuttering
- Loss of power while driving
- Double-cardan joint cover bolts -- two long, two short
- My Name in red
- 1988 suspension
- 1988 pickup a/c line help
- White crystals on my rear pinion flange
- Weber 32/36 install on 22r please help
- fuel line question
- Fuel Pump Issue
- 22RTE Shaking engine
- What’s this heater hose? 93 3vze
- 94 v6 altinator
- 95 4R 3VZ AT Cooling system
- 2023 '94 3.0 Rebuild Start
- TPS or ECM issues
- 1992 Toyota Radio and CD / Cassette Player
- 94 Pickup blowing whitish gray smoke/losing power on semi-steep incline
- Mirror needs Viagra? (droopy)
- 1995 extended cab engine build.
- what's this hose (heater hose?)
- Connecting Rod orientation
- 22250-35060 vs. 22250-35050
- 1990 RWD rear axle seals leaking
- Reviving my 1989 Xcab 4x4
- 2nd gen 4runner AC in 89 Pickup
- TPS adjustment on 1987 22-RE (VCC - E2 failure)
- Transmission noise
- 86 4x4 AUTO trans wires
- Installing an older 22RE in a 92 4wd PU
- Hello guys, Im back
- Strange buzzing/vibration coming from front wheel
- 95 advice
- 95 4runner back window won’t go up
- Darn thing won't start - COR, MAF?
- LCE or 22RE Performance master rebuild kit for 22re
- Hunting for more little plastic clips!!
- Installing 3VZE Headers and Keeping EGR
- Online parts book
- 88 yota driver front making awful rubbing noise
- Brake Calipers - Difference between Pre 89 and Post 89
- Cylinders 2, 4, 6 not firing.
- 3vze Fuel Leak
- Is burning oil smell a critical concern?
- Thoughts/Comments/Gotchas on possible acquisition of 89 SR5 v6
- HELP!!! 89 4Runner starts, then dies. Won't idle till warm. Won't idle above 650...
- Is this an OEM or aftermarket brake booster (2nd Gen)?
- Why has nobody ever made a 22R head with redesigned intake ports?
- 3vze bottom end with 5vzfe heads?
- Help identify this plug 1986 pickup(sunrader)
- Opinions on 1993 Pickup
- Large bang after timing chain change
- What size WHEELS will fit my 89 Pickup?
- Running board mounts?
- Failed CHP VIN verification
- Head gasket replacement issues Metal or Graphite recommendations
- 3VZE Wobble in Harmonic Balancer
- Throttle Position Sensor
- 22RE crank no start despite fuel pressure
- Need Help Diagnosing Milkshake Cause
- Timing chain cover issues
- '92 Pickup Milkshake - Headgasket or Timing Cover?
- Help with removing PO steering hack
- Chasing EGR error
- Help Identify This Part! Thanks..
- M8 x 1 fuel banjo bolt?
- 2WD vs 4WD Reliability and Maintenance?
- 22re Engine Swap - 2wd to 4wd
- Dead Horse
- 91 Toyota pickup brake actuator
- Newbie 1992 4Runner 3VZ-E -Engine Stalling after warmup problem
- Working on the truck......2 questions......brakes and screeching sound!
- Blower motor issue-I’ve read several threads
- A couple tips if removing a W56-B transmission (1984-1988 Pickup IFS RWD)
- Need help with backup lights
- How to: remove oil pan (1984-1988 Pickup IFS RWD)
- 1986/87 Toyota 22RE Itasca rv power steering?
- Stalling, difficult idling at stop lights
- 50RPM idle plz help
- Torsion bar adjustment
- O2 Sensor Wiring problem
- Alert! free '93 4x4 "St5"
- Trucks just losing battery power
- low compression on 4 cylinders
- Brake booster and master cylinder - not matching up
- Rear end noise with video
- Brake master fitting size
- Aftermarket radio, factory anti theft
- 3VZE valve clearance
- 93 Toyota Pickup 22RE - Code 31
- Need An Ignition Control Module
- Engine code 12 pops up when starter does not engage. 1991 toyota 4runner 3VZE
- 3vze automatic more gutless than it feels like it should be.
- 1986 4runner lift rear leaf spring help
- 1994 22re won’t take throttle
- Jumping T and E1 kills the engine...
- 92 igniter wiring
- Discount Tire Damage
- 1994 DLX Reg Cab Pickup 4wd Muffler kit
- 92 pickup, oem e locker swap
- Rear window rolls down intermittently in cold weather, every time when warm
- Fuel gauge issue
- Which parking brake cable needed??
- Unknown connector during tilt steering swap
- Where Does This Wire Go?
- 95 4Runner vibrates when stopped runs smooth after
- 22RE Wire ID help
- Trying to add lights to ashtray and lighter
- sPOD install
- Only my low beams work
- 1994 4x4 5 speed rebuild kit
- Shift Lever Bushings
- 22RE CEL stays on solid when connecting TE1 & E1
- 93 22re surging idle to no start.
- A340h transmission, all neutrals
- 19909 Toyota 4WD V6 3VZE
- Gray shifter knob?
- 1992 SR5 Front Seats
- Oil in coolant - Bad housing - But deceiving
- Tailgate Help
- '87 4runner (22re) - Interior electrical power shut down while driving
- 92 AFM question
- Knock at 2k rpm and Timing Chain Replacement
- Dashboard Parts 1994 Pickup
- 90' SR5 3.0 - Fuel Smell & Cold Start
- Odd 4WD Connector
- 93 pickup 22re intermittent fuel pressure drop
- 22RE , help me sell it
- 1990 4runner starts, dies under load, then no acc.
- OME Suspension Parts Question
- Need help to diagnose a noise.
- 86 4x4 build w/lots of pictures
- Need to tap a wire to activate flashers from keyless entry
- Grease for starter
- Use factory starter relay or ford solenoid?
- Need help diagnosing "The Phantom Squeak"
- 86 22R Carb Swap Question
- Problems with EFI Turbo
- Wind noise from sunroof
- fuel guage, sender kaput?
- 91 2WD axle flip too tall?
- Exhaust Wrap on T100
- '92 4runner, 1UZ/A341e/Dana 300
- 3.0 Hot on Freeway Climbs
- EGR Code 7 1
- 86 extended cab.. 19 gallon tank retrofit?
- Window wind deflectors
- Auto transmission shift lever leak help A43D
- WTB 84-88 New rear sliding window xtra cab tinted.
- 22RE Lagging Acceleration And Ignition Timing
- Lack of power and engine sounds like an airplane
- Can't get auto shift lever back together??
- Lack of power and engine sounds like an air plane
- Valve cover knock 95 4Runner 3vze
- 22-re coolant builds pressure/then overheats
- So pleased with this vender....
- Failed emissions, head scratching.
- Slave and master clutch cylinder question
- 93 Toyota pickup parking brake help
- BW wires from/to Igniter and Coil
- Rear window seal for 88 extended cab
- 1988 gauge Cluster
- Looking for wiring harness opinions
- 91-97 land cruiser brake pads-front
- extended studs?
- 3VZE Overheating, stumped.
- Rock Sliders
- 1993 Roll Over - What Should I Do?
- Open / Closed loop on 1993 22RE. How to tell?
- 85-88 22RE Throttle Body part identification
- 3VZE Low Oil Pressure When Warm
- 94 pickup 22RE head gasket replacement
- 86 4wd Window Problems
- Looking for a Speedo Gear for a 1990 4wd / 31s / 4.88s / 5 spd
- 1992 truck 3vz-e
- 86 22RE: NO click no start
- 3VZE water pump casting surface on block is rough
- Oil leaking from shifter tower
- 91 toyota 22re p/u ... Ignitor no spark!!!
- 1987 pickup vent window rubber replacement
- Rough Shifting Transmission Early 3VZE Automatic
- Swapping 94 22R-e into a 92 pickup
- 1993 T100 Rebuild
- Bumper Brackets (Rear)
- Guts out
- Spare tire carrier
- Arp headstuds
- Bucket seat swaps
- SR5 Manual Cluster Harness Repinning (1st gen 4Runner; '84-'88 Pickup)
- 5VZ swap: ORS headers, worth it?
- 85-88 extended cab rear window dimensions vs standard window dimensions??.
- 87' Stress cracks on T-case
- Power Steering Return Hose
- 4Runner rear shock x-reference
- Intercooler for a 22rte
- 91 22re blowing oil and exhaust
- What is this connector for?
