Chasing EGR error
Old Nov 9, 2023 | 04:40 PM
DiabloYota's Avatar
Chasing EGR error
'91 2wd pickup. 3.0 6cyl
Truck is new to me. I'm getting code 71. Reset, drive again, get code again. I've tested the EGR valve by sucking on the vacuum hose while at idle. Resistance is felt; valve actuates and engine dies. According to standard advice, that's a pretty good hint that the valve is OK.
Next, I replaced all vacuum tubes related to EGR. Lots of 3mm and one larger one. Still getting the code.
Before I spend a bunch of money on parts, what could be next steps? Any way to test the temp gauge that is in the intake side of the EGR valve? Any way to test the VSV switch that the EMC controls?
Old Nov 9, 2023 | 06:01 PM
DiabloYota's Avatar
Followup - right after I posted this, I found the method for testing the VSV. Apply 12v and the solenoid should click. Mine does, so I'm ruling that out for now.
What next?
Old Nov 9, 2023 | 06:52 PM
scope103's Avatar
Here's most of what you want to know: http://web.archive.org/web/201204061...77exhaustg.pdf
Not mentioned in the FSM is ... crud. The output (exhaust gases) from the EGR valve goes to a long tube extending into the plenum. Over time, the plenum can fill up with "crud," mostly from the PCV system. If there is enough crud the tube can be blocked. It is smaller in diameter than the hole in the plenum, so if you have trouble pulling it out its coated.
Old Nov 9, 2023 | 09:50 PM
DiabloYota's Avatar
Right...I have that diagram.
If the plenum insert was clogged, then the test of the EGR valve would fail, I think. Adding vacuum to the valve causes exhaust gas to flow into the plenum, which stalls the engine at idle.
Still...I'm going to pull it and take a look.
I'll be testing the temp sensor next.
Old Nov 10, 2023 | 06:58 AM
DiabloYota's Avatar
Tested the temp sensor. I'm getting no continuity at all.
Old Nov 10, 2023 | 10:03 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I don't have a 91 FSM in front of me, so not sure on actual testing specifics/parameters, but I believe you won't get any continuity unless sensor element is heated to XXX degrees. EGR is disabled on a cold start engine.
Old Nov 10, 2023 | 10:16 AM
DiabloYota's Avatar
Should have 11 - 16 k ohms at 212 degrees. Less at higher temps. I tested it at 212 and room temp.
Old Nov 10, 2023 | 11:15 AM
scope103's Avatar
Try plugging in a 15k ohm resistor to see if that clears the code. That's not a long-term fix (well, for some folks it apparently is) but it will help you rule out other problems. The sensor is ~$200.
Old Nov 10, 2023 | 11:46 AM
DiabloYota's Avatar
Is that the resistor that comes in the block-off kits?
Old Nov 13, 2023 | 07:24 AM
DiabloYota's Avatar
Final word on this: I put in a 10k resistor and the check engine light stops. I tested my temp sensor and a known-good one to be sure my procedure is correct. Mine is dead, for sure. The good one shows all the right resistance numbers.
I'm going to get a new temp sensor.
Old Nov 13, 2023 | 08:21 AM
scope103's Avatar
Good work!
bacon8302
Apr 13, 2015 08:38 AM
krytellan
Jul 19, 2010 04:20 PM
pnyk1d
Jun 23, 2008 07:39 PM
Alex 400
Feb 18, 2008 08:59 AM
95RunnerSR5
Jul 18, 2007 05:55 PM
