Sponsored by: CARiD
3.0 egr
Old Apr 9, 2015 | 04:04 PM
bacon8302's Avatar
3.0 egr
How can you tell if an egr valve is bad? And also can a vacuum leak throw a check engine code?
Old Apr 13, 2015 | 08:38 AM
Terrys87's Avatar
I am sure the 3.0 EGR valve is nearly the same as a 22re. You can apply vacuum to the metal pipe and you can here it open or close with vacuum. To test I just use the power of my lungs. https://www.yotatech.com/forums/f199...l#post51647988
Leaks will cause the check engine light to come on and not throw a code in my experience. A clogged EGR can throw a code.
JHalcyonM
Sep 14, 2015 01:10 AM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
pplusent
Sep 2, 2015 11:56 PM
