Replacement nuts and bolts
Old Jan 19, 2024 | 11:09 PM
Brokton's Avatar
Does anyone know of a place that sells replacement bolt kits for a 90 Toyota pickup 22re? I am specifically looking for the bolts that hold the front disk brake to the caliper as some were already broken by the previous owner an I broke 2 as well. The other thing I am looking for is a bolt kit for the timing chain cover, water pump and fan clutch.
Old Jan 20, 2024 | 12:04 AM
h0runner's Avatar
22reperformance.com and your local dealership will have everything you need. Also any hardware store that carries JIS bolts/nuts.
Old Jan 20, 2024 | 04:02 AM
snippits's Avatar
Here is the link for the hardware kits. I used a timing cover kit, and a water pump kit when I changed head gasket/timing chain on my 92 22RE.
https://22reperformance.com/hardware-kits
Old Jan 20, 2024 | 04:56 AM
prcnctoyo's Avatar
90101-12144 caliper bolt toyota part number my local dealer online price is $2.54 ea. Dealer can verify part numbers for your truck.
94512-01200 washer part number
I've been able to get most but not all hardware from the dealer. Ordering online gives a discount. Recently I needed the steering knuckle to dust cover bolts but they are discontinued. Couldn't get it thru partsouq either. Only one other bolt I needed that was discontinued.
Old Jan 20, 2024 | 07:22 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Bolts that hold a caliper on have a high grade. Best to get something comparable.
Old Jan 21, 2024 | 08:59 AM
mechkw's Avatar
I got mine directly from the Toyota Dealer. They had them on the shelf
Reuben1
Feb 21, 2021 03:27 PM
old4runner
Aug 8, 2010 02:25 PM
Frank Evans
Jul 24, 2010 08:27 PM
xxxtreme22r
Oct 22, 2009 07:10 AM
