Use factory starter relay or ford solenoid?
Old Sep 25, 2023 | 04:34 PM
cashmoney00's Avatar
I’ve got an 89 4Runner with the 22re in it. Hasn’t run since 2006. Working on getting it running and it looks like the factory starter relay is either weak or dead. Turn the key and I get a click from it. Hook a wire from the trigger on the starter direct to the battery and I get a thunk from the starter.
Any particular reason I shouldn’t just go with a ford remote solenoid and skip the factory relay altogether?
Old Sep 27, 2023 | 02:56 AM
RAD4Runner's Avatar
I bet that there is nothing wrong with your starter relay. However, it may have been WIRED WRONG FROM THE FACTORY. I discuss it here:
https://www.yotatech.com/forums/f116...runner-307493/
It would help if you can share where and what your starter relay looks like because your 4Runner year is transitionary and schematics/wiring may vary.
Old Sep 27, 2023 | 05:00 AM
Found that post not long after making this one. Going to try and look at that this weekend.
Old Sep 29, 2023 | 08:32 AM
Quick test shows that pin 1 has only .25v and not 12v.
Yes the battery is brand new and is sitting at 12.4v currently.
Old Oct 1, 2023 | 12:27 AM
RAD4Runner's Avatar
Sorry, what's pin 1?. Pls let us know what u are refering to, and what your starter relay looks like and where. Pls help us help u.
Old Oct 5, 2023 | 08:09 AM
mechkw's Avatar
Getting a thunk from the starter tells me it is working--- Are you sure the engine will turn and is not seized up from sitting for 17 years?
Old Oct 5, 2023 | 10:25 AM
I meant pin 4. My bad. But it looks just like this.
The thunk was actually the bendix being frozen and the plunger smacking in to it. Broke the starter down, free'd that up, regreased it.
The ground wire on the battery terminal (some crappy aftermarket clamp on one) was loose. Tightened that down.
Turned the key and she coughed a few times but got her fired up and idling. Now to continue with the tune up.
Jimmyjohn
Jun 1, 2024 10:14 AM
Justin Pelow
Jun 22, 2022 02:18 PM
cbr600rx7
Aug 31, 2016 10:23 AM
mikruiser
9
Jan 19, 2013 04:52 AM
madmin
Sep 3, 2008 06:56 PM
