Only my low beams work
Old Oct 11, 2023 | 09:55 AM
The.jesus's Avatar
I have a 1992 4runner. My low beams work, but my high beams, rear running lights, and dash lights don't work. My blinkers do work though. Pretty stumped here
Old Oct 12, 2023 | 06:39 AM
sodkil's Avatar
I purchased a vehicle as of late that has programmed headlights. Whenever I first drove around evening time I was unable to get the primary pillars to work, or at least, until I got to some place that had no streetlamps. This is excessively present day for me. Additionally when another vehicle approaches around evening time the headlights consequently plunge.
Tutuapp 9Apps
Old Oct 12, 2023 | 07:00 AM
scope103's Avatar
If your turn signals work, you probably don't need blinker fluid.
Amazon Amazon
Headlights and tail lights don't have anything to do with each other (except for the switches being on the same stalk). For the headlights, pull one of the lamps and check for continuity through the high beam filament. Then check for continuity to ground (the headlights are ground-switched) through the pin connected to the R-Y wire (be careful doing this is if you're using a multimeter to check; the R-W wire goes to battery when you turn on the headlight switch). If your truck came from Canada (daytime running lights), the diagnosis is different.
The taillights, front markers, and dash lights all work through the "Tail" relay (usually) found in the left-kick-panel fuse box. I'd start by checking that relay.
Old Oct 16, 2023 | 11:27 AM
SoCalToyotas's Avatar
I'd pull your steering column cover off and check for power coming out of the switch. It is the only common item between the headlights and tail lights. If its defective it can cause that
antispin
Oct 25, 2014 03:18 PM
quiggs12
Nov 22, 2010 08:42 AM
Nimrod
7
Sep 26, 2007 04:08 PM
hirsche23
Nov 2, 2006 12:20 PM
SIGSays
Feb 21, 2005 05:38 PM
