fuel line question
Old Dec 17, 2023 | 03:29 PM
jasheehan's Avatar
fuel line question
Hi, I'm a new 4Runner owner, but have had Land Cruisers for 20 years.
I have a 93 4Runner with V6.
I am replacing the fuel tank and ran into some issues with the fuel lines.
I could not get the line off which goes into the top of the tank and could not get the bolts off the inlet/outlet of the fuel filter. So, I need to run some new fuel lines. I tried to source new lines the from Autozone, and Advanced; they did not have metric. They have 3/16" line that should work since I can re flare, but I cannot fine the connectors that screw into the fuel filter and the line into the top of the fuel tank. Any recommendation on where I can source either the entire fuel line, or the connectors (8mm). Thanks.
Old Dec 18, 2023 | 04:02 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Google "metric brake line tube nut"
Old Dec 18, 2023 | 04:38 PM
cashmoney00's Avatar
Use a different fuel filter that has threads that are easily available. You could convert the whole fuel system to AN. Just adapt the threads on the tank to a -6 and then run that to the fuel filter and then a -6 to whatever end is at the fuel rail. Think it’s a banjo.
Old Dec 22, 2023 | 02:17 PM
mechkw's Avatar
If the tank is fresh and out of the vehicle, you can take it to your local radiator shop and have them solder in some SAE line fittings in both 3/8'' for the pressure side and 5/16 for the return and not worry about adapting anything other than the AN parts. If I was going to that extent, that's what I would do
hookerpilot47
Sep 28, 2017 09:31 AM
itsivxx
Feb 7, 2016 03:38 PM
Shock5
Jun 15, 2006 02:24 PM
AJatx
10
Jun 14, 2006 12:20 PM
BartMan
May 31, 2005 01:59 PM
