PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 [158] 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Diagnosis help
  2. 3VZE High Idle Problems
  3. cylinder heads
  4. plans for exo cage on 87 flaT BED????
  5. A 96-04 model Throw out bearing in my 89
  6. truck knocking really bad....where to start looking???
  7. Skid Plate for 95 4Runner
  8. new to the truck world. have a few ?'s
  9. no start
  10. Frozen Cam bolt
  11. '87 4Runner Spark knock - 22re
  12. My New Toy 89 4Runner
  13. grease?
  14. 1992 4runner 3.0 fuel pump no cat timing belt issues
  15. 94 Brake booster
  16. Stupid Starter
  17. Hydraulic Tenisoner on 95 4Runner?
  18. 22RE CK Eng light on, replaced TPS, now REVs off and on in idle
  19. DOH! My head hurts! Pics!
  20. I needs y'alls help on picking a lift :)
  21. 4.56, 4.88's, 31's and hwy rpm
  22. 90 P/U 22r overheating and losing charge HELP!
  23. Manual or auto?
  24. No second gear
  25. Fluttering noise?
  26. Check engine light on
  27. Hi there, 87 pickup problems..
  28. Crankshaft and Camshaft Bolt Removal Tool
  29. Windshield trim
  30. 3vze engine problems??
  31. 3.0 timing belt pre-replacement questions
  32. 22r head on a 22re? Does that work?
  33. Hard start - gas smell '90 3VZ
  34. a very weird problem
  35. Trouble code troubles
  36. Cheap Performance upgrades??
  37. 22re head gasket; Corroded Head, now what?
  38. Need help on CA. smog!!!!!!
  39. milage problem I have with my 4runner
  40. sourcing trim parts
  41. e-locker retrofit ????'s!!!
  42. My Runner with 33X10.5 BFGs
  43. 3VZE misfires, backfires, and lacks power. VAFM?
  44. Where are my window relays? 86' sr5 x-cab turbo truck
  45. 86 tranny swap-seal questions
  46. Do Our Clutches Just Go Out?
  47. more diff locking Q's (sorry guys)
  48. Made a couple improvements to the truck (pics)
  49. Temp Fix for a EFI Fuse Blowing, tell me if this is a good idea
  50. recent rebuild... still not running right???
  51. Another Damn Coolant leak!!!
  52. 3.0 head bolt torque
  53. Downpipe/bellhousing bracket
  54. Clicking in dash affecting idle?
  55. No start..but wait...now it starts?
  56. Coolant Overflow Bottle - 91 toyota pu 22RE
  57. High Beam Issue
  58. Unable to set base timing
  59. Immediate help needed with speedo cable please look
  60. timing cover install....
  61. v6 calipers
  62. tail lights
  63. LSD and Steering
  64. My Custom 2nd Gen. Trail gear bumper (pics)
  65. sliders install
  66. Love my Toyota but I rolled it
  67. Help My 15 Amp EFI Fuse Keeps Popping - How do i stop this
  68. 2nd Gen 4Runner Power Window Problems
  69. A/C not working?? Pressure Switch?? Fuse??
  70. 88 4Runner gets 34 ten fiddies!
  71. 3vze starts dies in 10 seconds..wont restart
  72. Sun roof wont open
  73. reman crankshaft for 3.0?
  74. rear brakes?
  75. buying 35's, I blame Bigblue....
  76. valve adjustment as per FSM
  77. Bracket lift with stock SR5 aluminum rims?
  78. 3VZE LH Fender Ground
  79. Look at this movement of my ADD side gear shaft "is this normal movement"?
  80. 95 4runner coolant hose identification and help
  81. Will 92 seat covers fit 88 runner seats?
  82. Clutch slipping?
  83. '87 4runner tranny
  84. -> My new truck
  85. 92 4runner 22re auto transmission
  86. '87 4 Runner
  87. What years did Toyota have the xtended cab and long bed combo rig?
  88. Bye Bye 20 year old carpet.
  89. 22re with 20r timing chain parts
  90. 92 4Runnner -> will not shift into gear, confirm my suspicion?
  91. driveline linkage spacer?
  92. What's This do???
  93. TPS Replacement Screws!
  94. head bolt re-torque questions please
  95. AC not working at idle.
  96. What are the consequences of running with out the rear ABS?
  97. Can not get spare tire down...and I need to! Any suggestions?
  98. temp gauge not working
  99. a340h no upshift after warming up
  100. 22re problem while cold engine
  101. Replaced Front Sway Bar Ends
  102. intake manifold cleaning?
  103. coolant system problem 1994
  104. replaced 22re cylinder head
  105. Looking for part (2nd post after some1 removed or moved my original)
  106. Location of temp senders(i've searched)
  107. 88 4Runner Quarter Panels
  108. Fitting aftermarket horns?????
  109. TPS and Timing help?
  110. exhaust line nuts
  111. 88 5 Speed Swap.
  112. no pressure in cooling system when truck is hot
  113. Electrial Relay Buzz no Start
  114. 1986 toyota 4runner 22re w/turbo automatic
  115. '91 4-Runner 3VZE clutch went out, need help
  116. Rear 4runner lift
  117. Do I need an oil pump?
  118. Engine/Tranny Swaps
  119. idle issues
  120. 95 v6 toyota pickup clutch problem.
  121. rpms and gas mileage
  122. Turns over but wont start.. help.
  123. oil leak from cylinder heads
  124. Spicer coils
  125. rod cap won't come off
  126. 88 yota ... HELP! Doesn't run right once warmed up
  127. Rust repair...
  128. 1986 4runner problem
  129. D@mn Deer....
  130. Broken pilot bearing is stuck, need advise
  131. Found 2 things in my garage tonite-Need Opinions on 1
  132. 4runner shell for an 89 pickup
  133. Xtra Cab useable space
  134. Converter not locking up 93 4runner
  135. head gasket / dealer issues update
  136. OEM Part Numbers
  137. Seafoam question
  138. Why??? So many Vacuum lines!
  139. Is there a "collar" that goes on the pilot bearing?
  140. Sunroof leaking
  141. JDM Swap wire harness Q's!!!
  142. Looking For Local Engine Rebuilder in Southern California
  143. Headlights suddenly stopped working
  144. door hinge?
  145. Cup holders???
  146. New '95 4runner!
  147. who here has the modded 3vz e
  148. Let's See Some Flatbeds
  149. Front End Vibration
  150. No more stuttering 3.0 V6, My FIX
  151. Air Control Valve- Power Steering Pump 3vze
  152. 22re rebuild - what gasket do I use...copper ring?
  153. Failed Emissions Test Need Help
  154. well I just finishing installing lift.
  155. Well, the bottom just fell out.....
  156. UH OH Coolant Leak...
  157. Help I have no POWER need some gurus
  158. Blown HG - Which Material?
  159. Goodyear Duratracs on!
  160. '07 FJ Cruiser Coils to '95 Runner
  161. bearing noise?
  162. 22RE compression test question
  163. 89 22re misfires at high rpm only
  164. High idle after timing chain replacement?
  165. 86' 4Runner
  166. 89 4wd trk high rpm misfire
  167. SR5 Oil Pressure Sending Unit Test
  168. Quick Timing Crank/Cam Alignment Question
  169. 2wd gear change options
  170. Old shifter seat
  171. IFS Steering Upgrades?
  172. Yet another Issue
  173. Stay Tuned! Gears, Tires & Lift, oh my!
  174. lower 4wd shifter linkage bushing? help?
  175. Replacement frame?? Where to get it??
  176. Help On lifting 92 pickup
  177. 1st gen runner tool storage?
  178. I am going to die without AC!! What to do?!
  179. What cam Should I Get?
  180. Blown Head Gasket?
  181. 22re Daily Driver Power lacks power
  182. 3vze manual tranmission flush. help!
  183. idle issues
  184. window trim/rubber scrubber/thing???
  185. cold start issue
  186. Brake line....MAJOR leak
  187. Aftermarket Oil Drain Plug Leak - HELP!
  188. where to buy rear lockers?
  189. Help ME start my truck!!!
  190. New Clutch & Burning smell - help
  191. Toyota sponsorship...in drag racing?
  192. Window not going up
  193. 3VZE vacuum
  194. Flywheel cover
  195. roll down windows with ignition off link needed
  196. Problem Throttle Position Sensor
  197. help with truck bogging out in 4 hi
  198. Alternator replacement tips? 3VZ
  199. Fuel filter (yuck) and a synthetic fluid swap done today.
  200. New Radiator Still Coolant Loss
  201. flex-a-lite 165 puller set up
  202. 3vze starter
  203. T-shaped electrical connection
  204. 89 pickup tacoma box swap
  205. Intro and my '86 Runner
  206. Where to order dealer parts online?
  207. seperate t case from tranny?
  208. I need to change my light bulbs
  209. rebuilt motor but no power....help wise ones
  210. Gentlemen, please Help? Oil dripping from two different places
  211. Goofed on a Head Gasket replacement
  212. Carburator air depurator hose question
  213. rear windows
  214. New Bumper What ya think
  215. Coolant Temp. Sensor/Switch
  216. Whats this stuff worth?
  217. MC clutch finally arrived
  218. What Is It?
  219. my rebuild.
  220. Any good shops in Sacramento?
  221. What to use for air injection manifold gasket?
  222. Over heating problem. 22RE
  223. Underdash Mounted A/C System
  224. Knock sensor 1990 3vze engine
  225. 93 truck box
  226. rear brake lines
  227. 3.0 backfires
  228. 1gen or 2gen 4runner
  229. Rear brakes?
  230. Code 43 for Ignition signal prob.
  231. Timing belt- problem getting cam alignment "perfect"
  232. 22re timing chain question, yes another !!!
  233. HELP! Broken down in Crater Lake Nat'l Park
  234. door jam wiring question
  235. 1" bodylift on a 94 AUTOMATIC Pickup
  236. Oil in TB(not from k&n) = bad PCV???
  237. 3vze motor mounts.
  238. Dont shoot me...but what is the part number for the 82 supra afm mod?
  239. whats the cheapest way to get a little more powerout of a 22re
  240. projector headlight conversion
  241. will 2nd gen tailgate latches work on 3rd gen?
  242. 2nd gen 4runner vehicle weight
  243. Running with no A/C compressor
  244. Float sensor adjustment...
  245. 3vze base fuel pressure
  246. AFM Swap Question
  247. Pros and Cons of the 3.0 V6
  248. Main girdle removal
  249. HELP! Seatbelt compatibility.
  250. 95 4runner Vibration
