22re rebuild - what gasket do I use...copper ring?
Old 06-30-2009, 06:53 PM
climber87's Avatar
I'm trying to figure out how this pipe is attaches to the bottom of the intake manifold. It looks like I had a small rubber o-ring. But in engnbldr's kit all I can find is a copper ring...will this work...is it enough by itself? Or is there a full gasket?
Attached Thumbnails 22re rebuild - what gasket do I use...copper ring?-p6300189.jpg
Old 07-01-2009, 05:47 AM
climber87's Avatar
I think I'm just going to go find a rubber oring that'll fit
Old 07-01-2009, 07:15 AM
deserthound's Avatar
Yes, it does require a rubber O-ring. The copper ring in the kit is not for this connection.
Old 07-01-2009, 07:25 AM
mojoman's Avatar
engnbldr's kit doesn't come with it, I had to order it from toyota
Old 07-01-2009, 01:34 PM
854x4's Avatar
It needs a rubber o-ring, and the pipe attaches to the manifold by two small bolts. When I replaced mine I used one from a harbor freight metric o-ring kit, I even put some grey permatex on this connection for added protection ,no leaks. Also copper washers should be for fuel connections.
Old 07-01-2009, 02:16 PM
Teuf's Avatar
Wow that one stumped me too, no gasket in my Lc'E kit, i found the O ring at last on my floor. I used grey goop as well.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
09-04-2015 09:27 AM
Snort
07-19-2015 07:03 AM
Quick Reply: 22re rebuild - what gasket do I use...copper ring?
