grease?
Old Jul 8, 2009 | 09:06 AM
machine23's Avatar
grease?
correct type of grease for sealing electrical connections from water damage?
Old Jul 8, 2009 | 09:33 AM
Junkers88's Avatar
dielectric
Old Jul 8, 2009 | 09:45 AM
TNRabbit's Avatar
Di-electric grease. You can get one-time use packets at any parts store. It's predominantly to prevent corrosion on connectors, rather than to prevent water damage, but it works for that, to a point.
Old Jul 8, 2009 | 01:00 PM
machine23's Avatar
yea thats what i was referring to. corrosion mainly...
Old Jul 8, 2009 | 01:16 PM
iamsuperbleeder's Avatar
please don't use any RTV or silicone, lol
Old Jul 8, 2009 | 01:23 PM
MudHippy's Avatar
FYI...
Dielectric grease is usually silicone based. It can also be used on disc brakes and to recondition old rubber components(i.e. weatherstripping).
Old Jul 8, 2009 | 03:40 PM
KVRunner's Avatar
You can usually find packets of the dielectric grease right at the counter of your local parts store.
Old Jul 8, 2009 | 04:00 PM
machine23's Avatar
yea i know what you guys are talking about. i work at my local parts store.
who uses silicone for that??? lol..
i could understand using silicone if you werent planning to disturb the connection again...
Old Jul 8, 2009 | 04:05 PM
Originally Posted by MudHippy
FYI...
you know what I meant
Old Jul 8, 2009 | 04:52 PM
abecedarian's Avatar
Dielectric grease is generally non-conductive and used primarily for excluding moisture. Because it's non-conductive you have to make sure any physical / mechanical electrical connections are clean and secure.
Alternatives to dielectric, if you're worried about corrosion, are anti-sieze lubricant and dissimilar metal coatings like NoAlox, KopperKote, etc., sold in the electrical department at many hardware stores. You have to be careful with them though since they are conductive and if used on a multi-conductor connector can cause shorts between terminals.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
