Help My 15 Amp EFI Fuse Keeps Popping - How do i stop this
Old 07-05-2009, 11:21 AM
simpsons721's Avatar
Red face Help My 15 Amp EFI Fuse Keeps Popping - How do i stop this
my truck is currently not working because my efi fuse keeps popping
i dont know what to start to check if this is happening
also one fuse was lasting 2 weeks until it would pop
this morning i used 3 to try to get her to fire but they all kept popping
so what should i check for a short somewher?
Old 07-05-2009, 11:40 AM
Justinlhc's Avatar
Any recent problems, upgrades, floods, damage or accidents?
Old 07-05-2009, 12:15 PM
i did do the relay rear window fix before the problem happened (i dont think this is the prob) still didnt fix my rear window
also when this first happened i took it in to the dealership and they replace the fuse and fixed the bad connection at efi harness
do you think the connection is bad again in the efi harness
i have to research the efi harness because i dont even know where its located
Old 07-05-2009, 12:23 PM
akaphilly's Avatar
check out your o2 sensor wires. make sure it hasent started burning to the exhaust. most likely thats your problem
Old 07-05-2009, 12:30 PM
annoyingrob's Avatar
^^ yes. Also, check that the e-brake under the dash hasn't worn through the harness.
Old 07-05-2009, 12:54 PM
Justinlhc's Avatar
Sounds like the first place I'd look.
Old 07-05-2009, 04:02 PM
myyota walks's Avatar
I've heard of a bad fuel pump doing this.
Old 07-05-2009, 04:35 PM
could it have been when i replaced my relats for the rear window
Old 07-05-2009, 05:10 PM
gametom's Avatar
i had this issue mine was shorting near the fuel injectors
Old 07-05-2009, 05:29 PM
Justinlhc's Avatar
Considering it's a completely seperate circuit, I'd say no. Unless you did some crazy wild messy wiring job and cut into the wrong wires somewhere.....
I'd look at the obvious first. You say there was a bad connection at the harness at one time and it was fixed once before. Is there a reason you don't want to check that out??
Old 07-05-2009, 05:31 PM
swapped89's Avatar
i had this problem it was my o2 sensor wires burning on the exhaust in front of the cat
I just cut all the bad burnt wires off and spliced the good parts back together
Old 07-05-2009, 05:36 PM
ya the reason i dont want to check it out right now is because my car is in the mountains stuck where no service is and to tow it home will probably cost 150
so hopefully i can get a ride there tommorow to try and fix it
thanks for the help guys just trying to gather all the info possible
wafoogalla
11-02-2016 11:02 AM
80Truck
07-24-2015 03:12 PM
PlayAwhile
07-20-2015 11:36 AM
rushw
07-18-2015 01:46 PM
dpridgeon3
07-09-2015 01:18 PM
Quick Reply: Help My 15 Amp EFI Fuse Keeps Popping - How do i stop this
