1986 4runner problem
Old Jul 2, 2009 | 04:34 AM
nicksmith18vt's Avatar
i just changed my oil and filter yesterday. i drained all of my oil and put in 5 quarts of royal purple synthetic oil and a k&N oil filter. i let it run for 15 minutes before i drove it and when i went to back up it had hardly any power and when i gave it gas it blew out alot of smoke. now its stuck in my friends parking lot because it won't move without blowing a massive cloud of smoke. it sounds like its running fine when i start it up, it just won't move. i let the oil drain for about 3 hours today before i put the screw back in my oil pan and put the new oil in, could that have hurt it.
Old Jul 2, 2009 | 05:19 AM
Marc's Avatar
Help us out here. 4 cyl, 6 cyl, manual, auto?
What's the oil level at now?
Old Jul 2, 2009 | 05:36 AM
toyota4x4907's Avatar
I think putting 5 quarts in hurt it more than sitting with no oil for 3 hours....
Old Jul 2, 2009 | 05:50 AM
TNRabbit's Avatar
5 quarts is good for the 3VZE, not so good for the 22RE...
Old Jul 2, 2009 | 06:35 AM
waskillywabbit's Avatar
Was it runing poorly before the oil change? You sure it was engine oil? Sounds like something else is going on we aren't hearing about yet.
Old Jul 2, 2009 | 10:51 AM
LITLRED's Avatar
I just did an oil change with 4.5 qts of Royal Purple with a Fram filter and she runs just fine.
Old Jul 2, 2009 | 11:58 AM
Junkers88's Avatar
Same here. I'm guessing that Wabbit is right in that there is something else that we're not seeing or being told. Of course if the OP would decide to come back and give us an update it'd help........
Old Jul 2, 2009 | 01:22 PM
Kiroshu's Avatar
ok its a 22re and you put 5 quarts which is already too much oil and thats prolly some of the prob you need to drain about a quart out and see if that helps. Oh and um you didn't need to drain oil for 3 hours.... 20 mins tops is all you need..... is it auto? sounds like maybe a trans prob too um more info and what happen preivous to oil change?
Old Jul 2, 2009 | 05:08 PM
wyoming9's Avatar
Interesting I run all 22rec engines and I use 5 quarts of oil in each one since day one. then I don`t run the tiny stock size filter.
I also think there is another problem
Old Jul 2, 2009 | 05:20 PM
Kiroshu's Avatar
dunno but i know 22r's don't like too much oil they will let you know quick they don't like it. still awaiting info from this guy if it did this anybefore or what... not enough info... might just have a pcv system prob if its buring oil or the girl my be a bit worn out in the rings and or is leaking past valve stems... ERG stuck open? take vac line of egr and see if it helps. mass air flow? too thick of oil? timing?
Old Jul 2, 2009 | 06:13 PM
fixed it
sooooo.... i fixed it. the deal was that the transmission fluid pan was in the place where a oil pan normally would be on a vehicle. i drained all of the transmission fluid out thinking it was oil. but it wasnt as dumb as it sounds... the transmission fluid wasn't red like it should be, it was oil colored amber, like dirty oil. so draining all of the transmission fluid out was a good thing since i just put in 4 quarts of automatic transmission fluid today when i figured out the problem. the oil pan and plug are under the front axle close to the engine. so, i re-drained the new/old mix of bad oil and new royal purple that cost like 9-10 dollars a quart and put new royal purple 10w-30 in and it runs great now. it still blows some smoke, but i'm assuming that it's because i overfilled with oil. i added 5 quarts on top of an already "full" engine. i dont see any problems as of now from the situation other than the smoke coming out of my exhause. it was a good excuse to go to napa auto parts to do some parts shopping. i also got a license plate backing and clear plastic license plate cover for the front so that it won't rattle as much. cleaned the license plate and it looks nice now. i had a question about putting a pcv vent on my engine. here is a link of another guy, maybe one of you, who put one on his 4runner that is the same as mine. the picture is a little more than halfway down the page. it's a picture of the guys hood open and his red engine with a "pcv vent" on the engine.
http://images.google.com/imgres?imgu...%3D36%26um%3D1
sorry about that long url. also, i've had some "problems" starting my car for a while now. when i turn my key i have to have the key turned over for about 10 seconds until my 4runner starts. what could the problem be. thanks for all of the input guys! i didn't expect such fast responses that's why i didnt check this until now, also i was changing oil and transmission fluid today. i will be putting up pics of my 4runner soon.
Old Jul 2, 2009 | 06:14 PM
4 quarts
by the way when i put in the new royal purple 10w-30 i put in 4 quarts instead of 5. my back tires are wearing more than the front, what could be the issue there. this is a great site. i'm happy i found it
Old Jul 2, 2009 | 06:17 PM
WOW. Just WOW.
Glad you figured that out before you REALLY made a bad situation a nightmare.
Old Jul 2, 2009 | 06:21 PM
Kiroshu's Avatar
OMG! You had nealy 10 quarts of oil in there!!!!! You are exptemely lucky it did not blow you are very very very lucky. It is gonna smoke a while now yea from bookoo oil....!!!! wow. i figured the truck not moving was trans problems. wow ur lucky don't do that agian. Lol and no ofense but i'm guessing you have never changed oil before... atleast not on a 22r cause thats kinda bad you didn't know what was the oil plug.
Old Jul 2, 2009 | 06:58 PM
CyMoN's Avatar
first off did you even check your dip stick after you added the oil
http://www.youtube.com/watch?v=Mj5ms9PJDNY
second is it a automatic or 5 speed if it is a 5 speed make sure to put gear oil in and not ATF.
Old Jul 3, 2009 | 03:47 AM
Duelertoyota4x4's Avatar
I dont know how far your friend's parking lot is, but i cant belive you didnt kill the tranny driving it with little to no fluid in it.... You lucked out.
Old Jul 3, 2009 | 03:55 AM
TNRabbit's Avatar
Geez, dude; that sounds like something JIFFY LUBE would do~
Old Jul 3, 2009 | 06:44 PM
whokrz's Avatar
Old Jul 3, 2009 | 06:55 PM
neilan's Avatar
this has to be one of the first EPIC FAILS i have seen on yotatech
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
