I needs y'alls help on picking a lift :)
Old 07-07-2009, 08:56 PM
4runner901's Avatar
im about to put my spare on a CBI tire carrier with a hi lift.
with that said that will add approx. 100 to 115 pounds to my rear end
my 4runner is already higher in the front and i want to put 1.5" poly spacers in the rear.
is that a good idea?
Old 07-07-2009, 09:02 PM
tc
tc's Avatar
What year 4Runner?
Old 07-07-2009, 09:05 PM
4runner901's Avatar
its a 1995
Old 07-07-2009, 09:08 PM
tc
tc's Avatar
OK, so just the standard rear sag.
IMHO, the spacers on coil springs is fine. Replaement coils are better, but the spacers are fine.
Old 07-07-2009, 09:09 PM
whokrz's Avatar
I was very happy with my heavy duty OME rear springs they lifted it about 2.5 inches http://www.gentryoffroad.com/php/gen...uctreview/ome/
Ball joint spacers seem to be popular for the front of that year.
Old 07-07-2009, 09:18 PM
4runner901's Avatar
any other opinions?
Old 07-07-2009, 09:41 PM
4runner901's Avatar
now im going for 2" rear spacers
Old 07-08-2009, 09:49 AM
Yotakid23's Avatar
I've got poly spacers in my 90, they'll do you fine. Just be ready for it to feel funny driving at first. The big thing that I came into was that with the addition of the spacers my sway bar was what almost seemed like, locked in one place. It made my runner really stiff. I just took them out and have been running like that for a while now without any problems. There is a lot of body roll but you get used to it. Hope that helps.
Old 07-08-2009, 09:58 AM
Lumpy's Avatar
I'd get new coils...I was debating on getting spacers as well but decided to wait...save and get coils. It'll do better with the added weight as well.
I was curious about the roll in the rear...I pulled my front out and she rolls a bit, just can't drive like its a lil coup that's all. Does pulling the rear make a bigger difference on roll? I'm sure it helps a bit on the trails as well?
Old 07-08-2009, 12:42 PM
tc
tc's Avatar
In my experience, going from front/rear swaybars to rear only was pretty minor. Going from rear only to none was pretty significant.
Old 07-08-2009, 12:51 PM
VSU_4runnin's Avatar
if you go with spacers get high strength metal ones, I dont know much about what the poly spacers can take, but i would think the added weight would cause the spacers to prematurely degrade or shrink
Old 07-08-2009, 01:54 PM
space-junk's Avatar
i can vouch for the OME coils as well... they are by far one of the best mods that i have done to my runner... they lifgted the back end up above stock height and in order for me to bottom it out it takes about 300 lbs in the back and a VERY twisty and hilly road...
plus, they ride like a dream on the street(better than stock) and they have an unbelievable amount of flex offroad...
they are pricy, but worth it...
Old 07-08-2009, 09:19 PM
4runner901's Avatar
i ordered 4crawler offroad 2in spacers from there.
once installed do i need to do anything else?
extend brake lines? anything?
Old 07-08-2009, 09:22 PM
for 2-3" nothing... other than maybe have the alignment checked.. but if your not doing the front, than you might not have to worry about it
6th Gear
19
12-10-2019 07:31 AM
live4soccer7
09-03-2015 12:29 PM
rondogracing
07-05-2015 12:32 AM
88Toy
7
06-17-2015 09:40 AM
Quick Reply: I needs y'alls help on picking a lift :)
