Tach Troubles
Old Apr 30, 2009 | 05:43 PM
Chutchman's Avatar
Tach Troubles
I have started having some problems with my tach and they seem to be getting more frequent. At first it only did it when in was really wet outside but now it does it anytime it wants. Basically it is not reading the correct engine speed. Sometimes it works great and other times It is all over the place. I noticed at a stoplight today that the tach read zero while my engine just hummed a nice idle. And then when I pulled away from the light my tach jumped up to 2000 and climbed fast and high up to around 5000 about the time I shifted. My shift couldnt have been higher than 3500.
Any ideas to fix this one?
Old Apr 30, 2009 | 06:28 PM
scuba's Avatar
Is this a factory tach, or an aftermarket..?
Old Apr 30, 2009 | 06:32 PM
Jay351's Avatar
If its factory, clean your coil/igniter to body ground and your battery to body ground.
Old May 1, 2009 | 05:31 PM
Chutchman's Avatar
It's the factory tach
Old May 1, 2009 | 06:47 PM
1991(A)4runner's Avatar
This happened too me mabey a mounth ago, pull your distibuter cap, and clean the sensor that the tach is run off, and it should be fine
Old Jul 8, 2009 | 10:23 PM
Chutchman's Avatar
Well guys I have tried everything you suggested. I noticed a real improvement right after I cleaned the coil to body ground.
Could this have something to do with the alternator ground?
voiddweller
Oct 2, 2015 07:47 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
Matthew Perez
Sep 28, 2015 05:43 PM
128keaton
Sep 3, 2015 05:09 PM
