my rebuild.
Old Jun 27, 2009 | 03:39 PM
wii_tarded's Avatar
my rebuild.
Ok, I have had a hard time accessing the FSM so I'm not sure what I need. This is what I know I need:
Master Kit (includes Pistons, rings, rod bearings, main bearings, thrust washer, oil pump, full gasket kit, full bronze deep dish freeze plug set): $298. Plus $24.
www.engnbldr.com
Crankshaft: $160.
www.japanengine.com
Downey Headers: $425/chrome or $575/ceramic.
www.downeyoff-road.com
Top Gun Machine Shop (cleaning, boring, line honing, painting):
(865) 463-0787
Knock Sensor:
Clutch (and all accessories):
Water Pump:
Timing Belt:
Head Bolts:
Distributor:
Connecting rods:
If you can think of anything I haven't, let me know. This is my list for cost to keep track of. Also, if anyone knows where to get the new connecting rods, let me know.
Also, on a side note. Got a recall notice from Toyota a month ago for a steering connecting relay rod replacement, called to schedule the appointment and they told me that the head gasket recall hadn't been done. So on an 18 year old truck, I got all new head gasket work done for free, not only free, but a 2010 Camry LE as a loaner while they worked on the truck.
Old Jun 27, 2009 | 08:19 PM
bugs1961's Avatar
Unless you threw a rod or spun the bearings you shouldn't need to replace the crank or the rods. The machine shop will regrind the crank journals and check the crank for bending but very seldom does it need to be replaced. Same with the rods. The shop will check them for problems and fix what needs to be done. New rod bolts are standard, though. This is a routine part of the machine shop work.
The rest looks good. Download the FSM here: http://www.ncttora.com/fsm/index.html
I would put on new motor mounts since they will be removed during the rebuild anyway, and replace the rear trans mount if it hasn't been done.
Have a great time with it! Nothing like starting up and driving an engine you personally put together. Take care,
Bugs
pplusent
Sep 18, 2018 10:02 PM
voiddweller
Sep 28, 2015 11:21 PM
sonorn67
Sep 19, 2015 05:39 PM
Kytowboater
Sep 17, 2015 11:17 AM
calderp
Jul 27, 2015 09:58 AM
