seperate t case from tranny?
Old Jun 27, 2009 | 10:52 PM
Tubbyfatty's Avatar
So Im working on replacing my clutch and my friend says we should just seperate the t case from the tranny vs dropping the cross member.
Im not too fond of this idea because i dont want to reseal it and ive never split the 2 when doing a clutch.
So im going to tell him tomorrow i dont want to split em and should i just unbolt the x member and leave everything mounted to that or what?
Old Jun 27, 2009 | 11:43 PM
881stGenRunner's Avatar
do not seperate them, that is not a wise choice at all. just drop it all together as one unit. It will be much easier to leave them as is.
Old Jun 28, 2009 | 04:59 AM
scuba's Avatar
X2!!!
Old Jun 28, 2009 | 05:46 AM
waskillywabbit's Avatar
What does the FSM say?
Old Jun 28, 2009 | 09:43 AM
Tubbyfatty's Avatar
drop the cross member, but i think ths stupid auto store manual says to split em. ugh ineed to throw that book in the trash.
Old Jun 28, 2009 | 11:15 AM
Jay351's Avatar
We dropped everything as one peice. Just unbolted the d-shafts and x-member from the frame, unbolted the bellhousing and removed shifters and dropped it as one peice. Its pretty heavy, a tranny jack would be pretty tits here. We made by with muscle and a floor jack.
Dont split them. P.s any manual you are using except the FSM is a waste of time. Seriously, there is the 93 fsm online for free...
Old Jun 28, 2009 | 11:46 AM
Tubbyfatty's Avatar
Yea I just printed off the way to drop the tranny via FSM. Im going to throw that chiltions book in the trash later on lol.
Old Jun 28, 2009 | 01:41 PM
Jay351's Avatar
I got one of those for a 80-95 toyota truck... for free.
I looked at it once, said "my truck doesnt have that.." then put it on the top shelf and forgot about it. I dunno who can stand using those things, when you need it most, it just says "go to a mechanic"!
Old Jun 29, 2009 | 10:15 AM
75k5toy's Avatar
Don't throw that boook in the trash, give it to your FRIEND.
Old Jun 29, 2009 | 11:14 AM
Tubbyfatty's Avatar
lol ill just throw it in my garage somewhere.
Old Jun 29, 2009 | 12:17 PM
Ezrider_92356's Avatar
if i was doing it without an tranny jack i would probably split them with one i wouldn't split them. btw i keep my Haynes handy for things like torque specs and clearances other than that its pretty much useless
Old Jun 29, 2009 | 12:23 PM
TOYOTA 1's Avatar
x3 on not splitting them, just creates more work imo.
Old Jun 29, 2009 | 12:42 PM
Jay351's Avatar
Thats mean
I used a haynes manual when doing the oil pump seal on a 22re, it told me i have to remove the oil pan, so I did.... for NO REASON!!!!!
Old Jun 29, 2009 | 01:15 PM
Tubbyfatty's Avatar
Its gonna be fun doing this with out a tranny jack, maybe ill just bust out the welder and some scrap steel. Then get a cargo strap and strap it to the jack.
Old Jun 29, 2009 | 01:18 PM
Jay351's Avatar
Its not that bad, the worst part is trying to line up the splines when installing it. You need to lift and slide it forward. I watched my friend bench it into place, but it aint easy.
I suggest going and buying a tranny jack adapter (under $50 im sure for you lucky US boys), you can even take the thing back after you use it. But new tools are always fun..
So floor jack and muscles will work, but a tranny jack makes it an easy job.
Old Jun 29, 2009 | 06:44 PM
bigt's Avatar
hey jay i got my tranny jack adapter in canada at princessauto for 75 bucks not bad well worth it
Old Jun 29, 2009 | 07:25 PM
dropzone's Avatar
Fossilized
head over to harbor freight and pick up the trannie adapter!
Old Jun 29, 2009 | 10:22 PM
Tubbyfatty's Avatar
So I need some advice on removing the 2 bolts at the very top of the tranny about 11 and 1 oclock.
Ive gotten every single bolt out/broken loose but those.
I can get a tiny socket wrench on there but i cant break it lose.
Old Jun 29, 2009 | 10:27 PM
attach a bunch of extensions together and get to it from behind it. Its a pain, but you will be able to atleast get them broken loose taht way
Old Jun 29, 2009 | 10:29 PM
Tubbyfatty's Avatar
Like behind the t case? ^^
