whats the cheapest way to get a little more powerout of a 22re
Old 06-26-2009, 11:22 AM
88greyyoter's Avatar
i already have a k&n and custom exhaust on my pickup. what else is cheap and easy to do to get more power?
Old 06-26-2009, 11:28 AM
Teuf's Avatar
Cam, Headers, and if you go to larger tires, re gear it.
Old 06-26-2009, 11:32 AM
wheatus's Avatar
cheap and power are mutually exclusive concepts
Old 06-26-2009, 11:49 AM
Teuf's Avatar
i have found with the 22 re, beyond a few basic mods, you can spend a lot for not that much more power, you want beans save for a chevy 350 swap.
Old 06-26-2009, 01:23 PM
Slowstrike's Avatar
Advance the timing a few degrees and run higher octane fuel.
Old 06-26-2009, 01:36 PM
shore.runner's Avatar
Supra mod.
Old 06-26-2009, 01:46 PM
scuba's Avatar
3.4 Swap
Old 06-26-2009, 01:48 PM
totally a bro
Staff
vital22re's Avatar
there is no replacement for displacement.
Old 06-26-2009, 01:56 PM
iamsuperbleeder's Avatar
Originally Posted by scuba
3.4 Swap
it was only a matter of time, lol
I'll just say this... my current 22re rebuild in progress is costing my well over $1,500, and once done the truck will have a head with over-sized valves for better flow, an LCE intake tube (not to be confused with a cold air intake; the kit retains the stock filter box), .03 over bore, and PaceSetter exhaust from header to tip, and I expect to see under 150hp still...
Old 06-26-2009, 01:59 PM
Slowstrike's Avatar
god you meatheads he said cheapest!
Old 06-26-2009, 02:07 PM
FredTJ's Avatar
Do you understand that running higher octane fuel, in and of itself, will do nothing to increase the engine power ?
Fred
Old 06-26-2009, 02:26 PM
jackwolf's Avatar
Fred
Perhaps, but advancing the timing may cause it to ping and the higher octane fuel may address that, to a point.
Old 06-26-2009, 02:37 PM
Teuf's Avatar
so then you are always on edge thinking, dang is it going to run ok, good gas bad gas, keep it stock, rev the bugger n change oil monthly.
Old 06-26-2009, 02:39 PM
FredTJ's Avatar
Yes, that's correct. In my case, running the 3.0 I have advanced mine to 15* BTC with no problem(s), still running regular. The 3.0 does have a knock sensor. I don't know about the 22re.
In general, running higher octane fuel in an engine that doesn't require it will cause the engine to actually produce a little less power, certainly not more.
Basically all that higher octane fuel does is burn slower.
Fred
Old 06-26-2009, 02:49 PM
OrRunner's Avatar
i think i saw something about a "supercharger" off ebay for only 4.99 or some crap like that....
https://www.yotatech.com/forums/f5/r...-funny-184265/
this guy may have some good advice about cheap mods for power.....
Old 06-26-2009, 04:34 PM
Slowstrike's Avatar
precisely my point. If you advance the timing you need to higher octane to advance to the point of benefit. Usually I will advance to the point of pre ignition then back it off very slightly untill it is eliminated. Then run a higher octane fuel to ensure I am not getting pre ignition since it has more compression resistance. When I have done this myself with the 22re I have always gotten very noticeable response gains (not necessarily power gains). Anyway like the tittle says for a 2.4l 22re not a 3.0l 3zve.
Old 06-26-2009, 04:39 PM
Slowstrike's Avatar
Fred
its kind off pretentious to assume that it is a coincidence that suggesting timing advance and higher octane fuel in the same sentence have nothing to do with each other.
Old 06-26-2009, 04:48 PM
BigBluePile's Avatar
Take the hood, fenders, doors, spare and bed off and tell the passenger to get out then only run one (1) gallon of gas at a time and I gaurentee you'll have better 0-60 times.
These mods should cost you nothing, unless your truck gets impounded for looking like an abandoned vehicle.
Old 06-26-2009, 04:53 PM
Teuf's Avatar
Twaddle,.......... keep it near stock, keep it simple. Thats the reason for the 22re's longevity,OEM. Now, not to say i have not modified mine, but after 22 years its still a daily driver, what can i say. Just me .
Old 06-26-2009, 05:40 PM
jmcgowan's Avatar
cold air intake helped mine
Quick Reply: whats the cheapest way to get a little more powerout of a 22re
