Help On lifting 92 pickup
Old Jun 29, 2009 | 02:11 PM
yota9222re's Avatar
Ive got a 92 pickup stock with an extra leafspring now its got 31's on it but i wanna get 33 x 10.50's on it i dont wanna crank my t bars up because it puts so much stress on ur ball joints ive heard about bj spacers but id like around 2 inches of suspension lift i hate body lifts. any help would be good thanks
Old Jun 29, 2009 | 02:14 PM
Junkers88's Avatar
I'll say it before Scuba does.
Search on this site, this has been covered thousands of times.
You can fit 33/10.50's with no lift.
Cranking the t-bars doesn't ruin the CV's it just makes the ride suck.
Search, more info is out there.
Oh and welcome to Yotatech.
Old Jun 29, 2009 | 02:19 PM
4Crawler's Avatar
Well, 1.5" ball joint spacers and 1/2" of torsion bar adjustment would get you 2" of lift.
- http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
Another option might be a long travel IFS kit ($$$) or else a 4" bracket lift, but that is more lift than you need.
An cranking your torsion bars and/or ball joint spacers puts no added stress on the ball joints. Perhaps you meant CV joints and yes, the higher you go the more angle there is on the CVs unless you add a diff drop kit:
- http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Old Jan 25, 2012 | 11:23 PM
Hellvision251's Avatar
I know this posting is over two years old, but i also have a 92 and want the same thing. Seems that BJ spacers are a cheap and fairly good way to jack up the front end a bit. And not crank the torsion bars. Ill be doing it soon if anyone has an input or a certain kinda/company to go threw. And if anyone reads this, by getting the bigger shocks could that help they front end lift???
Old Jan 26, 2012 | 03:13 AM
rattlewagon's Avatar
I agree with the above, Start reading around guy.....
Old Jan 26, 2012 | 05:10 AM
jontoptek's Avatar
I have 4crawlers ball joint spacers, if you get the diff drop kit your cv's will be ok
Sep 4, 2015 09:27 AM
akaphilly
Jul 9, 2015 02:18 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
