timing cover install....
Old Jul 5, 2009 | 04:55 PM
yoterr's Avatar
i took off, my t-cover to fix the akwardly positioned timing chain and im trying to install it and the top left hand bolt wont go in???? took a flashlight and looked in and it looks like the cover is like an 1/8th to the right........but alllll the other bolts fit fine. im lost, its the right bolt, in the right spot as is the others and i cant figure out why this ones an 1/8th off,i pryed a bit at the cover, you guys think i bent the one side?? figures everything went smooth as pie comin off....thanks for any ideas
Old Jul 5, 2009 | 05:58 PM
iamsuperbleeder's Avatar
pics?
Old Jul 5, 2009 | 06:09 PM
abecedarian's Avatar
"We've secretly removed this user's engine block and replaced it with and Engine Builder's Choice engine block... let's see if they notice...."
were it me, I'd remove all the other bolts and start with that one... and see how things go.
Old Jul 6, 2009 | 01:04 PM
yoterr's Avatar
all try that i guess, i did leave them all loose and tried tapping that side of the cover but it didint budge, thanks for the help
Old Jul 6, 2009 | 03:45 PM
akaphilly's Avatar
are you using the same cover or a new one?
Old Jul 6, 2009 | 03:55 PM
and did you put the one that goes down through the cylinder head, below the distributor drive, in yet?
Old Jul 7, 2009 | 01:35 PM
yoterr's Avatar
NEW DEVELOPMENT!! i screwed up my headgasket (thats what was in the way of the bolt)
lol hilarious...not, so now i gotta do a headgasket and i didint even wanna spend the 10 on the t-cover gaskets... you guys think i can take off the head without taking off the exhaust manifold and intake?
Old Jul 7, 2009 | 07:34 PM
pntbol11's Avatar
it's possible but I would recommend taking them off. Your definitely going to have to remove the exaust.
Old Jul 7, 2009 | 07:36 PM
I'd remove the intake and exhaust (sorry. )
You'll need to clean the block and head mating surfaces to make sure the gasket can seat properly.
Old Jul 7, 2009 | 07:51 PM
Plumbrbob's Avatar
I always remove my heads with the intake attached but the exhast has to come off. I am carb though EFI may be harder. But really a HG job is cake i can R&R mine in a couple hours, maybe a good time to cleanup those valves, new oil seals, and lap those seats. maybe a RV cam & RV springs is in order as well? Engnbldr a good source on parts I can call him tommorrow morning and he will have parts at my door step the day after tommorrow AMAZING!
Old Jul 12, 2009 | 08:26 AM
yoterr's Avatar
lol, trucks already got an crawler cam, not sure about the springs, and its a rebuilt motor, decided to leave the intake manifold on, and yeah the exhaust manifold was a dumb question lol, guess ill take pics and clean sum stuff up along the way and post here, thanks guys
Old Jul 12, 2009 | 09:27 AM
Plumbrbob's Avatar
crawler cam eh?
I am running the 270/430 HO cam and I have ran the Torker
I think I should of went with the crawler profile
Old Jul 12, 2009 | 09:30 AM
yoterr's Avatar
runs nice, great power right off idle, just need a carb n header to take full advantage of it
Old Jul 12, 2009 | 09:32 AM
yoterr's Avatar
also quick question, just got my head off and everything has a good coat of black suit on it, does that mean im runnin rich? or normal....just wounderin
Old Jul 12, 2009 | 09:43 AM
Plumbrbob's Avatar
black carbon build up is a sign of running rich, I have always had some black.
Is it excessive build up?
Engnbldr said that the 260/430 profile was the best for my 20r/22r hybrid build but the power band really doest shine until I get some really crazy high R's but when it does kick in i clean lugs on my 36" swampers
Old Jul 12, 2009 | 09:52 AM
yoterr's Avatar
no not excessive...just looked like it, yeah its allways fun revin her out
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
icentropy
Jul 9, 2015 02:12 PM
