89 22re misfires at high rpm only
Old 06-30-2009, 08:38 AM
PrecisionTuneSC's Avatar
89 4wd 22re highr rpm misfire, replced, coil, ignitor, plugs, wires, and distributor, dist cap, and rotor. Keeps throwing an IGF code and has rondom but consistent misfire. Checked all groungs, even added 2. Ideas?
Old 06-30-2009, 08:42 AM
TNRabbit's Avatar
Is it possible your timing chain slipped a tooth? Upper RPM missing is consistent with cam timing issue...
Old 06-30-2009, 01:34 PM
Motor has less than 9,000 miles. It is the third motor for this truck. The first one died from oil pressure, second from a bent rod from the remanufacturer. This one is from a different reman place. It has ran fine up to now. except for a bad gas issue about 2 months ago.
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
kcaudill
07-20-2015 12:06 PM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: 89 22re misfires at high rpm only
