PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 [253] 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Pics of Downey header/y-pipe installed?
  2. 3vze wont time correctly
  3. High Pro 22RE Spec's R these good?
  4. 3VZE engine oil cooler
  5. Help!!!!Please! PCV grommet ripped...
  6. Diff/transfer case/tranny gear lube capacities? (Amsoil synthetic switch)
  7. hot 22re
  8. slight overheating
  9. 91 Pickup Torsion Bar
  10. Low oil pressure, engine deisels going up incline, and temp gauge fluctuating.
  11. trd ivan stewart wheels on my 93 pickup
  12. Won't Start
  13. Anyone used a BDS suspension lift?
  14. tired of searching need help with rear wiper assembly
  15. Yay I made some cool lock boxes!
  16. is my steering box bad
  17. TVV Removal... how?
  18. ready to bring up the sag on 94 runner
  19. 94 4Runner HG Repairs, (need advise).
  20. Running Board end caps
  21. New clutch weird noises
  22. New clutch weird noises
  23. Need a quick picture and some dimensions for power window swap
  24. creaky clutch
  25. cel light loss of engine revs
  26. Dash lights up when brakes are applied
  27. Blue smoke
  28. 4Runner 5 star rims on 94 SR5 4x4 pickup, need help!
  29. Pesky Cold Start Issues
  30. CEL Code 25 and 26 only when A/C is on
  31. Bumper re-fab advice
  32. Is this a symptom of a dying A/C compressor?
  33. do all 2cnd gens have A/C condensor fan??
  34. land cruiser jump seats in 4runner???
  35. 3VZE crapped out...
  36. More 3vz-e exhaust questions.
  37. Jumper Wire for A/C Recharge with R12?
  38. Head Gasket Recommendations?
  39. How many gallons (sorry if this is a repeat)
  40. what clutch should i get
  41. big tires
  42. ISR Parts
  43. So my CEL came on
  44. clutch issues
  45. engine rebuild removal.
  46. 92 4runner trailer wiring......where do i start?
  47. 3VZE Capatability
  48. 84 celica 22re --> 93 PU transplant possible?
  49. 33x12.50s on stock wheels
  50. What to pay for 1988 v6 4runner ? pictures Thanks
  51. 4Runner Does Not Start Some Times
  52. bearing direction
  53. Tranny/tcase seperation
  54. Anybody ever put on a Cummins 4BT in a 2nd gen?
  55. '87 pickup being parted
  56. Little toyota help, north GEORGIA
  57. Another cruiser coil/ball joint spacer install
  58. clutch install tips.
  59. another 88 4r rear window problem
  60. tranny help
  61. '89 4Runner + server rack + old pickup cap =...
  62. Splash Guard Clips
  63. Engine siezed
  64. Larger dash speakers 2nd gen
  65. raced modded f150 in my 01 sr5
  66. Clutch install gone bad?
  67. Fair Price for AISIN Hubs
  68. Leaky 89 4Runner
  69. engine noise
  70. Moving to snow country with a 2wd toy, will it do ok?
  71. Value of 4Runners varying in some states?
  72. Rusty Frame
  73. Bought a new engine, what else do i need?
  74. Not another 22re headgasket question thread!
  75. 4XInnovation Tube Doors Finally on!!! (pics)
  76. Annoying tapping!
  77. Installed new starter on 22RE; now grinding noise
  78. W56 Trans Rebuild In Progress-question
  79. Trying to ID tranny type
  80. front and rear IFS?
  81. 22re wont crank
  82. 3vze aftermarket up grades?
  83. Top off, raining hard = no fun
  84. AC recharge!
  85. Taurus Fan Hookup?
  86. Carb Question!
  87. Question about my 88 4runner motor mounts
  88. Front crankshaft key size
  89. 1993 toyota 4 Runner
  90. 3.2L 3vze stroker!
  91. Cylinder Head Bolts Socket
  92. New All-pro winch bumper
  93. To touch up paint on truck & use aerosal clear coat
  94. quick 22re exhaust manifold question
  95. Rear axle noise
  96. Shaky 2nd Gen Hoods Solutions
  97. holy expensive timing chain batman!
  98. 22RE Piston to cylinder clearance
  99. Need FEEDBACK about putting a header on a 22RE
  100. 1st gens & rear seatbelts
  101. my new truck ( check it out )
  102. first truck ( check it out )
  103. transmission question
  104. Piston Slap?
  105. fender flares
  106. 3.0 Dist alignment after HG?
  107. It's alive again!
  108. 3.0 Cylinder #3 Misfire
  109. SAS & X-over steering = pulls hard left
  110. My First Yota Rig..
  111. Intake manifold crud removal
  112. 2nd gen 3vze headgasket/rebuild engnbldr parts
  113. Panhard & Rear Sway Questions
  114. FYI: A little Beauty-- '88 on eBay
  115. 88 Timing belt question.
  116. 4runner wont shift
  117. Temporary disable switch for door buzzer
  118. Temporary Door Buzzer Disable Switch (95 Toyota Truck)
  119. Where To Find Taillights
  120. New wheels/tires pics
  121. 22re losing coolant, coolant tank bubbling
  122. 22re belt questions
  123. Fan shroud clearance
  124. Jasper 4 cylinder engine vs. Orient engine.....why the price difference?
  125. valve click
  126. What kind of grease for CV's?
  127. Good Grill's
  128. bent crossmember is it ok?
  129. TPS question
  130. lots of rain + windows down = no headlights
  131. What size is lower starter bolt in 3vz
  132. cheap and easy lift
  133. passenger side noise after turning engine off, 2nd gen
  134. 22RE Head Bolt Question
  135. 3vze...what are these passages?
  136. 1st time attempting setting Timing
  137. Relocate motor driven antenna
  138. 93 trans and 96 trans compatability
  139. Antenna for 1988 pickup needed, dont want Autozone speacial,PN needed!
  140. Short
  141. 94 4Runner Blown Head, need advise on options
  142. Help no blower???
  143. Air cleaner assembly swap question
  144. Help! Crazy pre-warm up noise from engine passenger side
  145. convert to cruise control
  146. terminal t
  147. Extended brake line length
  148. Damn the knock sensor!!!
  149. Ok, I've got a thousand bucks to spend on repairing my engine!!
  150. 3.0L #2 idler pulley mounting bolt torque?
  151. Rear quarter panels for '87 4x4
  152. Safest air intake?
  153. A use for the overhead cardholder in your 4R
  154. high idle and chugging
  155. Rear coil spring ?
  156. Chipped injector
  157. Tune up info needed
  158. Electric Fan - Single speed or dual?
  159. Tranfer case pivot linkage care & feeding?
  160. Troubleshooting the JERK!
  161. Finally rid of stupid key buzzer!!!
  162. Anyone done the YJ bikini top?
  163. where does the wire go
  164. A Million Miles on a Toyota Pickup...
  165. Need Some Advice upon replacing HG
  166. Put the 37's on again
  167. quick air box mod
  168. toyota 3.oL what do you think?
  169. Rear main seal questions
  170. About to buy a 1990 4Runner, 5spd, 22re... What should I check?
  171. 88 3.0 Idler Pulley question
  172. how clean should the surface be
  173. EFI Ground
  174. Need Pic of fuse block 94 4Runner
  175. over heating
  176. 22re broke down need advice
  177. Overheating
  178. nww guy here ! bumper questions
  179. distributer cap and rotor
  180. 3vze crank seal dilemma
  181. Lower ball joint replacement.
  182. No Compression
  183. wrong alternator by Mr Alternator
  184. code 4 problem
  185. Starter Problems
  186. Toyota EFI Mixture Adjustment
  187. 3vze + downey headers = underhood temps from HE%$!!!!!!
  188. Tie Rod problem
  189. Head Gasket Question
  190. 89 runner Suspension Qs
  191. Inside of driverside tire wearing.
  192. Engine parts CHEAP on eBay!!
  193. Factory Hand Throttle
  194. Adjusting ECU to compensate for tire size
  195. removed chrome windshield trim for paint job, now what!
  196. Distributor module ohm limit & rough idle question
  197. which shocks?
  198. My newest 4Runner (1989)
  199. Rear Jump seats???
  200. Help diagnose noise
  201. URD short shifter for your second gen Runner
  202. the age old question: chrome or black
  203. FAQ for Purchasing Used Toyota 4x4
  204. mufflers. (ya, i searched)
  205. AC parts 86 22RE best Sources??
  206. Changing Knock Sensor, need advice on some stuff
  207. Broken Timing belt help
  208. 22r Oxygen sensor check connector
  209. Marlin Front Hanger
  210. How difficult to change leaf springs
  211. Rear leaf reccommendations
  212. Valve Adjustment
  213. battery relocation
  214. ADD Front Diff & Auto Hubs
  215. lock out noise
  216. 22re header ?
  217. Check engine light - but everything runs fine
  218. rear window help needed
  219. 88 rear win. goes up but not down?
  220. exhaust opinions...
  221. Manifold stud size?
  222. water pump metal gasket with seal packing
  223. Fuel filter brand matter?
  224. 22re head bolt size
  225. 22re head bolt size
  226. Engine Rebuild.. While I am in there.
  227. need 1991 runner specs
  228. should or shouldn't replace the whole back gate???
  229. tranny pivot pin care & feeding?
  230. A/C Idle Relay?
  231. 22r/re quench and deck height....??
  232. 2nd gen fsm sunroof removal/install instructions
  233. quiet clicking from CV
  234. tailgate
  235. Lights
  236. Need help with wifes 93 4runner
  237. Starting Problems (fuel related) i think
  238. 1991 4 runner temp gauge
  239. Timing chain tensioner
  240. Drive line play/clunking
  241. oil cooler R&R labor Time
  242. weird clutch noise
  243. 1993 ext cab 4x4 for sale
  244. 88 4runner keeps cutting off?
  245. Any one here swaped there cv axles before?
  246. Timing belt change-- tensioner, cam/crank seal, and idler questions
  247. using heavier oil
  248. new center console
  249. 22RE Rebuild cost
  250. 93 4 runner kickin butt
