Dash lights up when brakes are applied
Old Jul 12, 2006 | 11:06 PM
ORB's Avatar
ORB
I've spent the last couple of days searching various toyota sites (4x4wire, pirate google, ih8mud, and of course yotatech). I have found a couple of others who have had this problem but I've yet to find a solution. On 4x4wire (I think it was kyle 22r) who found a bad bulb, but my bulbs seem to be fine. Another suggestion was a bad ground, but I searched in the driver kick panel and found 2 grounds but they seemed fine. There is also some connection with trailer wiring being the cause of this but I don't even know what to look for. Here are my symptoms
-apply brakes parking lights off-dash lights up (inconsistant flicker)
-after applying the brakes for a while, the dash lights sometimes go back out (like everything is normal)
-turn on tail lights-they flicker slightly at first, then stay on
If anyone has suggestions or needs more info please let me know...
Thanks
Old Jul 13, 2006 | 02:49 AM
TNRabbit's Avatar
Has anything in the truck gotten wet recently? Fuse block? Have you run it thru deep water?
Old Jul 13, 2006 | 04:38 AM
ac808m's Avatar
I had a similar problem a few months back. The culprit was my trailer harness. Try pulling it if you can. If you have OEM wiring it should be as simple as uncliping the harness and reattaching your bulbs. Its worth a shot if you haven't already tried it.
Old Jul 13, 2006 | 10:20 AM
ORB's Avatar
ORB
Nope.
What bulbs am I reattaching?
Old Jul 13, 2006 | 01:23 PM
rdlsz24's Avatar
How's your alternator? When my electronics start acting wonky the alternator is the first thing I check.
Rob
Old Jul 13, 2006 | 01:44 PM
04 Rocko Taco's Avatar
Im with rdlsz24 here, I'd look to the alternator first.
Old Jul 13, 2006 | 04:46 PM
ORB's Avatar
ORB
Rob
Voltages seem fine, the alternator seems to be doing its job. Anything specific to check?
Old Jul 13, 2006 | 05:20 PM
Yoda's Avatar
OK, I'll see if we can figure this out.
When you step on the brakes and the dash lights come on.......do the outside park lights come on too?
Remove both rear lamp assy's and unplug the harness to them. If problem is gone, it was in one of the lamps/wiring/bulbs....reconnect 1 at a time to figure it out. Make sure you have the correct bulb in the stop/tail socket.
Disconnect the trailer harness (not always easy to do). When I worked at an auto electric shop, most problems like this were in the trailer towing harness.
Report back the results to the above
Old Jul 13, 2006 | 06:51 PM
mr toytech's Avatar
check the solder connection on the back of the brake light bulbs. the two contacts are probably melted together.
Old Jul 13, 2006 | 07:37 PM
toyaholic's Avatar
had similar problem on my 89 corolla. when i applied the brakes, all of the dash lights came on along with the marker lights in front. i accidentally replaced a dual element bulb with a single element bulb in the brake light assembly and it shorted the two contacts together and nearly ruined the wiring. i bought an electrical wiring diagram supplement to the fsm and was about to start digging through the wiring looking for problems before i realized that it was the bulb and it was a simple mistake. it's usually the simple stuff.
Old Jul 13, 2006 | 09:41 PM
ORB's Avatar
ORB
Thanks a lot for the replies!
Yoda-I'll get on it and report back...
mr_toytech-I'll check that when I do the above
toyaholic-same as above
Old Jul 14, 2006 | 11:39 PM
ORB's Avatar
ORB
Problem solved!
Using Yoda's suggestion, I was able to pinpoint the problem to the passenger tail assembly. Turns out the filaments in the brake/tail bulb were touching (which I feel like an idiot for missing).
Thanks to those who helped me out!
Old Jul 14, 2006 | 11:53 PM
photoleif's Avatar
Originally Posted by ORB
Problem solved!
precision strike! nice job yoda
Old Jul 15, 2006 | 07:38 AM
Yoda's Avatar
Just a logical troubleshooting sequence
Old Mar 19, 2021 | 06:07 AM
NormanPH's Avatar
i have this same problem... when i step on the brakes the instrument cluster turns on and so are the front park lights turns on my ford focus mk2 '07... i do have a tail light problem as well, when park lights are on, and i step on the brakes, tail light goes off and brake light dont light up as well... all bulb are good and correct type... will try your suggestion... maybe a bulb socket issue... will update you..
Old Mar 19, 2021 | 09:37 AM
RAD4Runner's Avatar
Bulb socket. wiring to ground.
Old Apr 23, 2021 | 01:44 AM
NormanPH's Avatar
i have resolve this issue on my vehicle... it is a faulty brake light socket.. not the bulb but the socket itself... hope this helps...
Yamaha+Toyota=Fun
Aug 14, 2014 07:46 PM
frombozeman
Apr 13, 2010 09:07 PM
patrickryanb
9
Jan 18, 2008 07:20 AM
rider_1313
Sep 12, 2005 02:17 AM
shoei
Feb 22, 2004 06:46 PM
