Starting Problems (fuel related) i think
Old Jun 25, 2006 | 05:42 PM
josh61187's Avatar
Exclamation Starting Problems (fuel related) i think
I have a 86 4runner with thr 22re 136k miles and it all of a sudden started to have problems starting after it had been sitting for a coupile of hours. It only happened every now and then but now it it every time i let it sit. I changed the fuel filter, no luck. After it has been runnig it starts fine. but if it sits it has to turn over for minuite of so studdering and dieing, studdering and dieing, Then after that it runs good. only when it sits. I even replaced the fuel pump no luck. I am stumped need help
thanx josh
Old Jun 26, 2006 | 04:26 AM
TNRabbit's Avatar
My first guess would be fuel pressure regulator...
Old Jun 27, 2006 | 04:30 PM
josh61187's Avatar
it that a hard replacement
is it hard to replace it could that be someting i can get from a junkyard or should i buy it new
thank you
Old Jun 27, 2006 | 05:50 PM
TNRabbit's Avatar
go to the FSM link and check pressure per the manual: http://personal.utulsa.edu/~nathan-b...fsm/index.html
two other things that can cause this are:
1. Bad Cold Start Injector
2. Bad Water Temp Sensor (fools engine into thinking it's cold and dumps fuel via the cold start injector)
Old Jun 27, 2006 | 05:52 PM
TNRabbit's Avatar
FYI: that FSM is for a '93...
Old Jun 27, 2006 | 06:56 PM
mr toytech's Avatar
also maybe the cold start injector leaking???? or the cold start time switch??
Old Jun 28, 2006 | 02:00 PM
josh61187's Avatar
thank you for the help
Old Jun 28, 2006 | 08:36 PM
sleestak240's Avatar
I'm interested to know if you've made any progress on this issue. My '87 4runner (22-RE) does EXACTLY the same thing. Yesterday I yanked the cold start injector out and cleaned it off, but I'm not sure if I did anything for it. The truck still starts rough when cold. I'm planning on getting the multimeter out and checking the timing switch and some other stuff tomorrow. I'll probably check the fuel pressure regulator as well.
What is the best way to test the operation of the cold start injector without the special service tool indicated in the service guide? How have you guys gone about giving the injector a good cleaning in the past? I just can't seem to convince myself that it's anything other than this injector.
Old Jun 29, 2006 | 04:33 PM
mr toytech's Avatar
spray some carb cleaner in the inlet and power it up w/ a battery. just cleaning the outside isnt going to help if its clogged from the inside. if that dont help replace it...
Old Jun 29, 2006 | 06:24 PM
Yeah that's kind of what I figured...I might get on cleaning that again tomorrow. I did hit the cold start timing switch with the multimeter earlier and it looks like the resistance on the STA-STJ connection is a little high, so I might end up replacing the timing switch if I can find one and see what happens.
bigblue82
10
Jul 6, 2015 08:27 AM
serenity03k64
Jun 27, 2015 07:59 AM
jmc88runner
Jun 18, 2015 03:39 PM
Dennis140
Jun 17, 2015 10:37 AM
Toyota Punk
Jul 1, 2002 05:44 PM
