2nd gen fsm sunroof removal/install instructions
Old Jun 26, 2006 | 04:46 AM
AW1090's Avatar
Just what it says....My sunroof got all screwed up on me plus the glass was already cracked. I found the full setup with glass and all for 130 this past weekend. Just trying to find the fsm instructions for putting it in and taking it out. thanks
Old Jun 26, 2006 | 05:29 AM
snap-on's Avatar
his is for a pickup so i dont think it would have the sunroof detail you need.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Ive got a fsm at home and can look it up tonight if you dont come up with something else before then.
Old Jun 26, 2006 | 10:42 AM
AW1090's Avatar
Yup...I've checked that link and then discovered it was for a truck. If you can look it up in the book and get back to me....thanks
Old Jun 27, 2006 | 10:46 AM
halcyon0's Avatar
A little work!
To remove the sunroof, you have to remove the headliner. After you romove the headliner, you need to have another person support the sunroof, and then disconnect the wires to the sunroof motor and drain hoses, and then remove all the 10mm bolts holding it the sunroof assembly (black plastic tray looking thing). The sunroof should then drop down and you can slide the whole thing out the rear cargo area. Install is the reverse. Good luck!
Old Jun 27, 2006 | 03:45 PM
AW1090's Avatar
Thanks, I thought that's how it was just wanted to check it out on the instructions
89fourrunner
Feb 17, 2016 06:52 AM
ghostmoney
Aug 6, 2015 08:40 AM
vanion2
Jul 29, 2015 06:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
