transmission question
Old Jul 6, 2006 | 08:20 PM
wishmaster22's Avatar
How possible is it that since my 4runner went into a river before I bought it, some corrosion or build up on some key electronic parts could be causing my o/d not to come on and transmission sometimes feels like it might be slipping.
Wow that was hard to get out! whew! hope it makes sense. LOL!
Old Nov 4, 2006 | 02:59 PM
Anybody!
Please I need to figure out why the light does not come on.
Its a 94 v6 4wd .
Pushing the button in or out has no effect, also I cannot shift into 4h on the fly. I have to stop, put in into 4l and then 4h and then the 4wd light comes on.
Old Nov 4, 2006 | 03:27 PM
95RunnerSR5's Avatar
hmmm...i would get some electrical parts cleaner and spray all your connections..then start troubleshooting ..check this link for info..
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Nov 8, 2006 | 01:04 PM
Thanks Kyle, I'll give that a shot!
Old Nov 8, 2006 | 04:50 PM
rezrunner92's Avatar
If the trans had water in it you need to have it rebuilt, no need to worry or hurry, but if it was filled with water for more than a few minutes you are about to have major problems.
If the OD OFF light on the dash never lights up I would say you have a problem in that circuit that needs to be repaired first. IIRC, the light should come on no matter what the trans is doing. All the light is for to let you know if YOU have overdrive cancelled. It could be something as simple as the bulb is burned out so it can't complete the circuit. Good luck.
Old Nov 8, 2006 | 05:10 PM
Babypig's Avatar
Pull codes and see what happens. Same way that you pull engine codes just watch the O/D light instead of the check engine light.
Old Nov 9, 2006 | 04:10 PM
Guardian_Saint's Avatar
Try to replace the vacuum that goes to your right side fender, it might leak air somewhere there, mine was leaking at the gas fitting which locate back of the manifold or air chamber.
Old Nov 10, 2006 | 06:35 PM
Could that also be causing my 4h on the flye not to work?
Old Nov 10, 2006 | 06:36 PM
Not sure on how to pull the codes, I don't have and obdII reader
Old Nov 10, 2006 | 06:38 PM
I will check the bulb first, it get flooded at 60k miles now it has 192k.
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
