Tie Rod problem
Old Jun 30, 2006 | 12:09 AM
ryan808's Avatar
Tie Rod problem
I am trying to install a trailmaster 4" lift and Im at the point where I need to remove the tie rods on the differential bracket. I dont know how I messed up but the nut on the tie rod bolt wont come loose, it seems that the tie rod bolt is spinning with the nut. What do I do besides cutting the bolt, and if I have to cut the bolt, how much is a new tie rod?
Old Jun 30, 2006 | 01:32 AM
ldivinag's Avatar
can you insert an allen wrench in the cotter pin hole to prevent the bolt from spinning?
1. spray a lot of penetrating oil to loosen all the crud.
2. use heat on the castle nut just to expand it.
3. next time around, inner tie rod ends are like $40-50 from auto parts storem use tons of anti-seize...
Old Jun 30, 2006 | 06:33 AM
ryan808's Avatar
Ill try putting an alen wrench and opening it that way, thanks for your help
bigjstang
Jun 2, 2025 03:56 PM
westonian18
May 1, 2020 06:38 AM
Sep 4, 2015 09:27 AM
good-ol-boy
Jul 31, 2015 05:53 PM
ShakinIt2x
Jul 21, 2015 06:20 PM
