TPS question
Old Jul 5, 2006 | 10:10 AM
meswoleshane's Avatar
TPS question
I've read about adjusting the TPS sensor, and tried adjusting it. but I think its still going bad, it has to be adjusted ALL the way down even to get .01k ohms on IDL to E2, is this normal?
Old Jul 5, 2006 | 11:48 AM
AUYota's Avatar
Did you get the new cover sheet for the TPS Report?
...sorry I couldn't resist!
Old Jul 5, 2006 | 12:03 PM
Flash319's Avatar
The idle circuit is just a switch. It should be closed when the throttle is at idle position (low resistance) then as you open the throttle there will be a jump up to a very high or infinity reading when the throttle just starts to open. this tells the computer that it is not in idle condition anymore. The resistance at idle will very a lot but should be under 1k I think. .01k is 10 ohms is a very good connection. The critical thing is that it switches.
Old Jul 5, 2006 | 12:39 PM
so, even though it has to be adjusted all the way to one side to get the correct ohms, its ok?
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Sidherish
Aug 3, 2015 07:17 PM
Gone Fission
Jul 31, 2015 03:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
