Ifs 4wd and rear diff.
Old Jun 22, 2006 | 10:22 AM
akamoose's Avatar
On my 95 4runner the driver shaft on the pass is flopping and chunking in the diff. I have an 88 4x4 with ifs, can I take parts from that to make repairs?
My rear diff is also groaning during decelleration. The truck has 143k on it, I wouldn't expect the ring and pinion to need replaced, but who knows, would a overhaul kit probably fix it?
Old Jun 22, 2006 | 10:37 AM
shiftless89's Avatar
Change your gear oil and lube the shaft through the grease zerks
Old Jun 22, 2006 | 11:08 AM
akamoose's Avatar
Any advice on how to get the pass. driveshaft off? I got the nuts off but I doesn't seem to clear the bolts.
Old Jun 22, 2006 | 11:14 AM
callmej75's Avatar
Are you talkin about the cv I assume?
Old Jun 22, 2006 | 12:32 PM
mastacox's Avatar
You have to take the knuckle off of the top ball joint to help stretch the CV out a little more.
Old Jun 22, 2006 | 01:12 PM
akamoose's Avatar
Ok, I got the shaft loose.
Can anyone tell me if I can use parts from an 88 ifs diff, to replace parts on my 95?
Old Jun 22, 2006 | 04:37 PM
ZUK's Avatar
ZUK
You can swap the carriers (entire center section).
Old Jun 22, 2006 | 04:57 PM
tc's Avatar
tc
I'm confused. Are we talking about a front or rear diff here? Are we actually talking about a diff or CV axles?
Old Jun 22, 2006 | 05:17 PM
mastacox's Avatar
Does the 88 have ADD? If not, you can still use it if it your 95 has manual hubs, otherwise no dice.
Unless you plan on swapping out the internals, could be quite a bit of work, plus you need to worry about pinion backlash and the like.
Old Jun 22, 2006 | 06:11 PM
akamoose's Avatar
I plan to switch out the gears. Already have the 95 completely disassembled.
Old Jun 22, 2006 | 07:05 PM
mastacox's Avatar
Well, they're exactly the same. Are you changing the ring & pinion as a set?
Old Jun 22, 2006 | 07:06 PM
mastacox's Avatar
Old Jun 23, 2006 | 07:48 AM
akamoose's Avatar
If they are the same do I need to switch out the pinion? The pinion in the 95 is fine. thought I could probably just swap the ring gear and spool.
Old Jun 23, 2006 | 10:30 AM
akamoose's Avatar
Anyone know if I can just bolt the ADD stuff to the 88 diff. After looking at it for a few minutes it looks like I could just bolt those parts on, as long as the assembled dimensions are the same it should work.
Old Jun 23, 2006 | 02:18 PM
ZUK's Avatar
ZUK
So I guess the 88 and 95 are both V6 engines? That would mean they are both V6 center sections(chunks/3rds/carrier). The 88 does not have the drilled port on top for the cable assembly that goes to the top of your 95 carrier....so that means you won't have a working ADD but I'm not so sure if that's a big deal or not. I know it means the ADD light on your dash stays lit up.
Anyways, if you just swap the ring gear then most likely you will have a terribly load rear-end and it will start on fire after some time on the highway. So you really need to swap both the ring and pinion and get all the tolerances right....and I don't think there's enough memory on the internet to go thru the entire set up procedure. What you should do is send it to me to put new gears in the trashed "chunk". .....or just swap the whole 88 center piece in and break the ADD light-bulb.
Old Jun 23, 2006 | 02:53 PM
akamoose's Avatar
What is the cable assembly your talking about? I've got these things side by side and the carriers seem identical. The 95 just has a hold down bolt on the front cover for a bracket or something, it wasn't holding anything when I took it out.
The only different between these two is the add part, and it fits right onto the 88 carrier
Old Jun 23, 2006 | 06:11 PM
akamoose's Avatar
Ok, I put it all together and road tested it. It seems to turn fine with it up in the air, but driving it pulls to one side then the other, like it is putting power to one side then the other, what could cause this?
Old Jun 24, 2006 | 05:06 AM
ZUK's Avatar
ZUK
I guess that's good that they are the same....that means you don't have ADD (since you don't have the sensor connector at the top).
The pulling? Got a locker in that old 88 3rd?
tire pressures good?
You have a locker in there if you hear a slight click click click when going around corners......or a loud BOOMM!! kaSNAP!! when taking off from a green light on occasion. This is normal noise for a Locker
Old Jun 24, 2006 | 08:16 AM
akamoose's Avatar
Help!
I took it on the highway today and put it in 4wd. It runs like the power is switching back and forth to the front wheels, it lurches to the sides viloently, making the tires squawk. The only difference there was between these parts is the pinion on the 88 turns really easy, could the problem be because of preload and backlash stuff?
Old Jun 24, 2006 | 08:37 AM
mastacox's Avatar
Help!
Sounds like your 88 and 95 have different gear ratios! Do you know what they are?
