Bought a new engine, what else do i need?
Old Jul 9, 2006 | 01:24 PM
Chapman88SR5's Avatar
I just bought this engine. i need to know what old parts from my original engine i should replace to put on the new engine. the timing belt? this is a 1988 3.slow with 200k miles.
Old Jul 9, 2006 | 04:24 PM
95RunnerSR5's Avatar
you will need a gasket set, new timing belt, new serpentine belts, oil filter, and i would go ahead and replace the distributor cap, rotor, plugs and wires
Old Jul 9, 2006 | 05:34 PM
yota_krazy's Avatar
where did you get that engine? my friend just got one from oregonengines.com and we are currently putting it in. We opted to screw the crossover pipe and put downey headers in. At the same time we put in a centerforce clutch, clutch master cylinder and slave cylinder, new iginition parts, air filter, timing belt, water pump. get an entire set of engine gaskets from rock gaskets or another quality brand. good luck bro
Old Jul 9, 2006 | 06:27 PM
LOCKnGO's Avatar
Thats a new/rebuilt longblock? That's a good price.
don't skimp on the hoses, belts, thermostat and stuff like that.
Old Jul 9, 2006 | 07:28 PM
what brand should i use for the rotor, plugs and wires
oh and its not rebuilt its remanufactured
Old Jul 9, 2006 | 07:45 PM
Localmotion's Avatar
i thought they were synoninnoonninnonnyms
Old Jul 9, 2006 | 07:50 PM
oly884's Avatar
Guest
Here ya go:
This sucked, but I learned A LOT:
https://www.yotatech.com/forums/f2/big-engine-problem-5594/
https://www.yotatech.com/forums/f2/i-got-my-engine-6970/
https://www.yotatech.com/forums/show...&threadid=8107
https://www.yotatech.com/forums/f2/new-engine-break-8157/
https://www.yotatech.com/forums/f2/wooooohoooooo-8764/
Old Jul 9, 2006 | 08:06 PM
LOCKnGO's Avatar
I like Beck-Arnley(sp) parts because they are most of the time OE; Yeah sure you pay a few $$'s more but it is still cheaper than the stealer and the quality is better than the aftermarket crap.
Old Jul 9, 2006 | 08:11 PM
dwh91102's Avatar
As far as gaskets, if its a long block like pictured. You will only need, oil pan, valve cover, upper & lower intake, and thermostat gaskets. Put a new timing belt on, also new plugs, wires, and cap as said above. The new clutch is a good idea to while your in there. As for the radiator hoses, if there in good condition, I wouldn't worrie. All yeah new belts to.
Old Jul 9, 2006 | 10:11 PM
Bumpin' Yota's Avatar
nice compilation oly882!
I like Lee's (firefighter emt) link here....
http://www.asashop.org/autoinc/JULY/techtips.htm
He may have saved me some issues amidst my HG replacement!
Ah owning a 3vze is alot like owning a GMC tyhpoon or cyclone, if you arent an ASE certified mechanic, it soon will make you one! LOL
Old Jul 10, 2006 | 07:39 AM
alright i am going to buy new plugs, rotor and cap for sure. this engine came with a lot already, heres some pictuers...
and no the cat did not come with the engine
Old Jul 10, 2006 | 08:13 AM
i got this from a company in arizona called Engines Direct. how much did the headers cost you? does anyone have a link to a good source for distributor cap, rotor, and new plugs and wires?
Old Jul 10, 2006 | 08:27 AM
callmej75's Avatar
Replace all of your fuel injection brass washers too to ensure no gas leaks...and watch out for the cold start injector line coming off of the fuel rail...the old ones tend to be brittle and bust once you get everything hooked up and you get fuel pressure back on it. I also got my injectors ultrasonically cleaned and new grommets for that.
Old Jul 10, 2006 | 08:38 AM
where can one get those brass washers? I lost a few of them pulling my fuel rails...
here kitty kitty kitty! lol My cat comes running whenever I do that. (could have something to do with popping the lid to canned cat food whenever I do that too! lol)
Old Jul 10, 2006 | 08:43 AM
callmej75's Avatar
Get a hold of Phil...I ordered all of mine through him. We discussed the FSM and all of those little washers.
Old Jul 10, 2006 | 09:33 AM
dwh91102's Avatar
bumpin I still have a few in my garage if you need them that bad, I can tell you this they are a rare find, anywhere other than a toyota dealer.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Yota.Jay
Jul 23, 2015 08:08 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
karbin
Jul 5, 2015 11:37 PM
