How do you take the crank pulley off?
Old Mar 23, 2003 | 10:46 AM
oly884's Avatar
Guest
HOW DO YOU DO IT!?!?!?!? I've gone through 2 ratchets so far (they busted) and no luck. I can't get it off. Is there a special tool to use for this?
Old Mar 23, 2003 | 06:07 PM
toyota parts dude's Avatar
crank pulley
to get the pulley off your were doing it rite by trying to get the big nut off. they usually are really tight you need to get a real long 1/2 inch breaker to get it loose even then it can still be a pain
Old Mar 23, 2003 | 06:23 PM
oly884's Avatar
Guest
Ok, so I got that off. What about the cam pulleys? I broke 2 wrenches, 1 socket, 1 ratcet, and a partrage in a pear tree. No, but seriously, I can't get those off at all. I used a 4 FOOT breaker bar!!!:cry:
Old Apr 5, 2003 | 03:55 AM
jx94148's Avatar
I hope you are using Craftsman tools or some other brand with a lifetime guarantee.
Over on pirate 4x4.com I read that the easiest way is to set up a breaker bar against the left framerail and blip the starter to start the nut off.
Edit: I have no idea about the cam pulley nuts, sorry.
Old Apr 15, 2003 | 07:03 AM
aviator's Avatar
VERY CAREFULLY!
Sorry I could'nt resist
Old Apr 20, 2003 | 08:35 PM
Glenn's Avatar
You can put a breaker bar against the frame rail and blip the starter. Works like a charm. Just make sure the ignition is disabled. Remove the coil wire or something.
Old Apr 22, 2003 | 01:09 PM
DH6twinotter's Avatar
Oly884--How'd you end up doing it? I think I'm in a similar predicament. Did you do the blip starter thing?
Have fun all.
DH6twinotter
Old May 10, 2003 | 01:22 PM
4runner4ever's Avatar
Maybe the reply is a bit late but here is the solution for your problem with those sticky camshaft bolts. You'll have to use a paint stripper and heat the bolt the first time you'll remove the bolts. Or just use a lot of force.
Toyota uses Loctite on those bolts and this glues secures them to the crank or camshaft. Once removed you'll see a red or green material aplied to the bolts.
This stuff is heat proof up to just above the boiling temp of water.
So heat m up but replace your seals incase you overdid it.
Old May 10, 2003 | 08:44 PM
oly884's Avatar
Guest
Well I got it off a long time ago, but I ended up sticking a wrench in the lobes on the cam and then proping it up on the side of the head, and broke a nice chunck off of the head, didn't matter though, I had a new engine. I did how ever heat it up untill it was glowing red and then spray it with wd-40
Bourbonblues
Dec 15, 2017 05:43 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
Corvoid
Sep 14, 2015 10:10 AM
JHalcyonM
Sep 14, 2015 01:10 AM
anndel
Sep 10, 2015 08:50 AM
