high idle and chugging
Old Jul 3, 2006 | 02:01 PM
clint's Avatar
i finished changing the timing chain and head gasket the 1986 22re starts at 1100rpm and idles at 1700rpm when i press on the accelerter it starts to chug i checked that i was set at top dead center that is good but when i use the timing light i am about 12 btdc but that was wear i was before i changed everything i hope somebody can help me please i am in a world of hurt .thank you
Old Jul 3, 2006 | 02:36 PM
clint's Avatar
i just adjusted the distributer housing with a timing light to 5 btdc but when i press on the accelerater it still chugs between 1200 and 1700 rpm i tried to adjust the idle with a screw and i tightened it as far as it would go and my tach said 900 rpm what should i do anybody please
Old Jul 3, 2006 | 03:22 PM
clint's Avatar
i looked under the hood and it says to short circuit the terminal t to adjust the idle my question is what is that and where is it thank you anybody.
Old Jul 3, 2006 | 04:19 PM
clint's Avatar
anybody out there can help me
Old Jul 3, 2006 | 04:35 PM
Elton's Avatar
did you back down the idle to 800rpms ?
Old Jul 3, 2006 | 04:53 PM
clint's Avatar
i backed down as far as the screw would go and that read 900 rpms on my tach it idles fine put as soon as i press the accelerter the motor fluctuates between 1200 and 1700 rpms what do i do
Old Jul 3, 2006 | 04:55 PM
Elton's Avatar
sounds like you got a vacum leak or there mixed up
Old Jul 3, 2006 | 04:59 PM
clint's Avatar
thank you elton i will check but if it was a vacum leak wouldnt the idle be erratic or it would be difficult to start thank you
Old Jul 3, 2006 | 05:02 PM
Elton's Avatar
idle would be erratic also did you burp the coolant system ?
Old Jul 3, 2006 | 05:07 PM
clint's Avatar
i added new coolant but what do you mean burp it
Old Jul 3, 2006 | 05:21 PM
Elton's Avatar
getting all the air out of the cooling system
Old Jul 3, 2006 | 05:31 PM
clint's Avatar
i just pushed on the hoses to get the air out and i adjusted the tps it worked fine i pressed on the accelerter and no hesitation then it came back it quickly returned maybe i bumbed when i was installing the air intake chamber does the tps have to be fine tunrd as well? thank you elton
Old Jul 3, 2006 | 05:37 PM
Elton's Avatar
sounds like your getting closer try adjusting the tps again
Old Jul 3, 2006 | 05:42 PM
clint's Avatar
i adjust the tps and know luck it continues to stumble while press on the gas.any other ideas elton thank you
Old Jul 3, 2006 | 05:47 PM
Elton's Avatar
it almost sound like its not getting fuel .... did you replace the sparkplugs and wires ?
Old Jul 3, 2006 | 05:54 PM
clint's Avatar
plugs, wires, cap, rotor are new i am stumped when i press on the gas slowly it will the rpms will climb to about 1900rpms then back to stumbling however when i quicky press on the gas it stumbles right away.thank you elton
Old Jul 3, 2006 | 05:55 PM
Elton's Avatar
have you replaced the fuel filter ? also is the idle smooth or chopy
Old Jul 3, 2006 | 06:09 PM
clint's Avatar
the filter is new and the idle is smooth only problem is when i press on the gas
Old Jul 3, 2006 | 06:16 PM
84sr5yoty's Avatar
Ohm out the AMF (Air Flow Meter)
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Jul 3, 2006 | 06:18 PM
Elton's Avatar
ether that or its the timing
