high idle and chugging
Old Jul 3, 2006 | 06:36 PM
clint's Avatar
well i removed the tps and it idled fine and when i pressed on the gas i had no problems go figure now the dilema what to do
Old Jul 3, 2006 | 06:37 PM
Elton's Avatar
time for a new or used tps
Old Jul 3, 2006 | 06:43 PM
clint's Avatar
is this easy to damage or can i check it
Old Jul 3, 2006 | 07:30 PM
Elton's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jul 4, 2006 | 10:57 AM
  #25
digdug's Avatar
When you adjusted the timing did you short the diagnostic plug under your hood? If not, this could cause all these problems. You have to do it like the book says or you won't get it right.
Old Jul 4, 2006 | 12:04 PM
  #26
clint's Avatar
digdug thank you but how do i short the diagnostic plug and where and what colour is it,i hope your right because i have been stressin over this all day at work.
Old Jul 4, 2006 | 12:09 PM
  #27
Elton's Avatar
look for Timing and Diagnostic Check Connector locations http://www.4crawler.com/4x4/CheapTricks/index.shtml
Old Jul 4, 2006 | 03:59 PM
  #28
clint's Avatar
thanks elton i properly set my timing by shorting it at 5 btdc when i checked the code for the check engine light i got a 7 and that is for the tps i just replaced the tps with another one and the same symptoms chugging when i press the gas does anyone have any ideas thanks.
Old Jul 4, 2006 | 04:11 PM
  #29
Elton's Avatar
so all the vacum lines look good every thing is pluged in right ?
Old Jul 4, 2006 | 04:16 PM
  #30
clint's Avatar
so it seems i am stumped elton
Old Jul 4, 2006 | 04:18 PM
  #31
Elton's Avatar
ya me too.... could it be the fuel injectors ?
Old Jul 4, 2006 | 04:33 PM
  #32
clint's Avatar
thanks elton i dont think so is there a way to check, i am still leaning towards the tps from what i have read about is when you reinstall another one you can not just screw it in you need a ohm meter and feeler gauges please elton or anyone else correct me if i am wrong thank you.
Old Jul 4, 2006 | 04:35 PM
  #33
Elton's Avatar
well if it ran fine when you unpluged the tps than it has to be it
Old Jul 4, 2006 | 04:42 PM
  #34
clint's Avatar
but i replaced it with another one from the wrecker but i am guessing that this is very finicky to set.
Old Jul 4, 2006 | 05:21 PM
  #35
MMA_Alex's Avatar
yes, you need to properly adjust the tps TPS Adjustment Instructions
You should also make sure the codes are cleared and then see if any come back
Old Jul 4, 2006 | 06:13 PM
  #36
clint's Avatar
thanks mma alex,how do i clear the codes? i just adjusted the tps with feeler gauges and no ohm meter dont have one but i am not sure why one is needed if you are just setting a gap.as soon as i started the engine the idle stays at 1200 rpm then press the gas and same old symptons hesitation 1500 to1800 rpms then back again i am sure it is something simple, any ideas
Old Jul 4, 2006 | 07:01 PM
  #37
MMA_Alex's Avatar
you're not setting the gap, youre setting the position of a resistive strip in the tps, against the throttle body. It needs to be angled correctly so the computer realizes how much throttle is being applied. Go out and buy a cheap multi meter. Its a good tool to have, and you can get halfway decent ones for less than $20.
As for the codes, unplug the ground wire from the battery, and let it sit a few minutes before reconnecting. I believe that should clear everything.
Old Jul 4, 2006 | 07:03 PM
  #38
clint's Avatar
thanks elton for code clearing,well i just cleared the codes and i am still getting 7 flashes which indicate a tps but i have messed around with it enough the only thing i did not do was use a ohm meter has this happened to anybody like maybe their friends second cousins neighbours aunts brothers girlfriends uncle thank you.
Old Jul 4, 2006 | 08:08 PM
  #39
digdug's Avatar
Yep, this happened to me. I went into it just like you did, chasing problems the wrong way. It sounds to me like you need to go get a multi meter and the feeler gauges and adjust the tps properly. The old cap and wires and tps are probably in perfect shape, just needed to adjust the tps. It is very finicky to get just right, mine would only give a problem while the engine was warming up, at temp it worked great and everything was fine. when it was cold it would idle @ 1800 and surge real bad. I found out the hard way that the previous owner had adjusted it wrong after I replaced the cap & button, wires, plugs, coil, tps, coolant temp sensor(both), pickup coil, and a few other things I can't think of right now. Good luck. As far as the meter goes i have really enjoyed the actron meter I got for christmas. I got the one with the tach and dwell meter, it runs @ $49.99 I think.
Old Jul 4, 2006 | 08:21 PM
  #40
clint's Avatar
thank you dig dug but if i just used the feeler gauges why is ohm meter so important because all you are doing is adjusting a gap.but i am going to pick up a ohm meter anyways i just dont see how it is relivant here for adjusting thank you very much.
