engine noise
Old Jul 9, 2006 | 08:55 PM
clint's Avatar
engine noise
ok here is the history i replaced the timing chain and the head gasket but when i took it apart i pulled off the tps.i put everything back together and properly and set up the tps with the help from everyone here thank you.now when i drive i get the chatter like it is the valves so i adjusted the clearence according to the manual and i still have the chatter i tried a couple of times but no difference.this noise is only when i drive not when i am in neutral could it be my timing thank you.
Old Jul 9, 2006 | 09:37 PM
DirtCheap's Avatar
Did you check the timing? is it possibly preignition or detonation?
Old Jul 10, 2006 | 01:16 AM
ovrrdrive's Avatar
Sounds like the timing is advanced to me too.
When I did mine I set it a little advanced at 8 btdc and I got pinging too so I had to drop back to 5.
Try setting the timing again and retard it a few degrees from where it is now and see if it helps.
edit. Actually I just saw you hear it in neutral too, I'm not so sure th e timing being off would make noise in neutral like that. If it's not the timing it could be anything. Get a stethoscope and narrow down where the noise is coming from.
It's possible that if you had to do a timing job a few valves were very slightly bent and it could just be them tapping on close.
Old Jul 10, 2006 | 04:58 AM
clint's Avatar
thank you, but i only hear it when i accelerate not when it is in neutral.so maybe i have to readjust my tps then set my timing again does this sound right.the reason i say that is because when i first put in the tps i already had my timing set so maybe one is compensating for the other in terms of that my idle is fine.how would you guys and gals restart this over (do the tps first then the timing second)thank you.
Old Jul 10, 2006 | 09:58 AM
clint's Avatar
anybody have any ideas how to retart setting the tps and timing again which one to do first and properly
Old Jul 10, 2006 | 10:19 AM
whitetaco02's Avatar
from what i understand you can't adjust the timing with the tps out of whack so i would do the tps first.
http://www.4crawler.com/4x4/CheapTri...PositionSensor
Old Jul 10, 2006 | 10:33 AM
MMA_Alex's Avatar
yes, the if the tps is off shorting the connector to kill the timing advance wont work correctly, and the timing will be off.
Old Jul 10, 2006 | 12:20 PM
Flash319's Avatar
When your short TEI and EI the engine rpm should drop. If it doesn't then your TPS is not right. Definatly sounds like your timing is advanced.
Old Jul 10, 2006 | 05:56 PM
it needs to be 5 tdc, correct?
Old Jul 10, 2006 | 06:57 PM
MMA_Alex's Avatar
5 btdc, yes
Old Jul 10, 2006 | 07:40 PM
clint's Avatar
well i adjusted my tps properly and reset the timing to 5 btdc with the motor shortened it idles excellant but as soon as i drive i can here the tickticktick sound so it does it when i drive but not when i am idling any ideas what that sound is
Old Jul 10, 2006 | 07:45 PM
MMA_Alex's Avatar
just to clarify the specs are:
22re - 5* BTDC
3vze - 10* BTDC
a ticking when you drive could well be an exhaust leak, or the injectors too. You said you recently changed the spark plugs? It may be worth pulling them and checking for deposits, and/or damage to the electrode.
Old Jul 10, 2006 | 07:49 PM
clint's Avatar
but wouldnt the leak be present when irev the motor in neutral? yes i am at 5 btdc on a 22re thank you very much.
Old Jul 10, 2006 | 07:51 PM
MMA_Alex's Avatar
yes it would. check the edit i did to the bottom of my last post (i was editing when you posted your reply)
Old Jul 10, 2006 | 07:54 PM
clint's Avatar
with the ticking present could i be doing damage to my vehicle while i drive it
Old Jul 10, 2006 | 08:01 PM
MMA_Alex's Avatar
if its detonation it can cause damage. it its the injectors its normal. if its an exhaust leak all its doing is hurting power/gas mileage
Old Jul 10, 2006 | 08:05 PM
clint's Avatar
what do you mean by detonation? how would i check this mma alex i thank you for your help this past week.
Old Jul 10, 2006 | 08:16 PM
MMA_Alex's Avatar
did you change the spark plugs recently? (i seem to remember you did...I think) take a look at the old plugs, and see if you notice yellowing, blistering, or cracking on the center insulator. Pull the current plugs and check those too.
Old Jul 10, 2006 | 08:33 PM
clint's Avatar
i just checked my plugs and i didnt see sany cracking or blistering nothing yellow they where all whitish brown
Old Jul 11, 2006 | 10:06 AM
MMA_Alex's Avatar
sounds like youre probably ok then. Its probably injectors. Someone can give you a better description of the noise they make.
