engine noise
Old Jul 11, 2006 | 12:21 PM
clint's Avatar
thank you mma alex
Old Jul 11, 2006 | 08:01 PM
clint's Avatar
well i adjusted my timing to 0 btdc with the terminal shortened and the clicking sound has somewhat disappeared but i am not sure if i should move it more?what can happen if i do move it more.so i am pretty sure that this sound is from my timing thanks.
Old Jul 12, 2006 | 04:18 AM
MMA_Alex's Avatar
you dont want to be at 0. it should be 5. 0 is probably very lacking in power. the spark plug needs to fire before the engine reaches tdc otherwise the piston has to start moving itself back down, because the flame takes time to burn across the cylinder.
Old Sep 28, 2006 | 07:33 PM
MAXIMUS1968's Avatar
I have this same problem and the only result of it being quiet is to put it on 0TDC. Can i move the distributor 1 tooth to compensate? to get it to 5BTDC? I have banged my head over this til i cant think
Old Sep 29, 2006 | 02:18 AM
  #25
TNRabbit's Avatar
Are you sure you got the timing chain on correctly (valve timing)? From what you describe, you may be a tooth off.
Old Sep 29, 2006 | 04:40 AM
  #26
Valve timing is correct, i just cant get ignition timing at 5 and not have pinging
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
