3VZE Capatability
Old Jul 11, 2006 | 05:45 PM
Cadaver's Avatar
3VZE Capatability
I recently snapped a rod in my 92 4Runner 3VZE and am curious what years would work. A friend more familiar with Yota engines mentioned only 90-92 3VZE V6 engines would swap directly. But, it appears the 3VZE engine was available for more years than 90-92. I found a 3VZE from a 93 runner and am curious as to what the potential differences and problems would be during installation into my 92 4Runner.
Thanks
Old Jul 11, 2006 | 08:26 PM
Bumpin' Yota's Avatar
hmmmm as far as the con rod I dont know, but the only difference that Im aware of is the timing belt tensioning system which would have no bearing on the conrods...
ttt - Maybe someone else knows?
Old Jul 12, 2006 | 03:10 AM
TNRabbit's Avatar
Any V6 thru 94 should be an easy swap. Are you talking complete swap or changing out engine parts?
Old Jul 12, 2006 | 04:18 AM
Ganoid's Avatar
there are bolt hole differences in how the motor mounts bolt to the block. There is only 2 styles I believe, 2 bolt and 3 bolt. There was a post on here somewhere a few month's back where I posted a few pics to help another member out who had purchased a newer motor to find he had some mount issues.
Old Jul 12, 2006 | 11:22 AM
Cadaver's Avatar
Thanks for the responses. Im swapping the entire engine. I've heard that the altenators may be different. I dont mind swapping some things out as long as it works with the ECU. I wonder if the motor mount thing will work if I use 93 mounts and where it mounts to the frame is the same. Anyone else have any more info on this swap? Perhaps I should try to find a 92 engine. Tough to find a one or two year only part, let alone engine.
Old Jul 23, 2006 | 12:15 PM
mtsumedi's Avatar
You find me a 1993 engine with similar miles and I will trade you for the 1992 engine I'm about to pull out of a donor 4Runner to put in my '93.
Old Jul 28, 2006 | 10:58 AM
Tdubbs05's Avatar
90 - 94 should be the same 3.0 v6. as you already know make sure it matches up w/ the ecu otherwise you're gonna be in for a lot more than you were planning.
Old Jul 28, 2006 | 06:10 PM
Cebby's Avatar
There are slight differences between the 89-92 engines and the 93-95 engines. 90-94 are NOT exactly the same.
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
