- Need some advice
- 225/75/15's tires with 4.56 gear ratio?
- Missing thermostat, intermittent overheating
- Gas tank pressure...
- Cold Start Injection and Injection Timer issue, power source?
- 1st Gen 4runner with gas pressure.
- Ex cabs single Frame w/ relocated axle and tank.
- 1994 4runner....ac prob and idle prob
- 89 to 88 3vze differences
- 2nd gen body swap to 3rd gen frame
- Another turn key; click; hummmm...
- Engnbldr Timing kits
- Hesitation at idle speed only??????
- 93 octane
- 1992 pickup transmission removal question
- new clutch noise
- Thermostat Info
- temp guage suddenly went to hot
- 3vze blown replacement head gaskets
- VG30et swap in a Yota?
- 22re rebuild. exhaust suggestions??
- Dash lights
- prothane poly bushings for control arms
- torque converter a340e
- layed up engine-start up tips.
- 1992 4runner 3.0 misfire cylinders 3 and 5
- Green Transmission Fluid?
- How are 4:88's on 31s or 32's?
- carbon cleanup
- Weird problem
- Can I Do It? Full 22RE rebuild in 3 weeks
- 4" lift and wheel backspacing
- Help Please 25&26 CEL
- 3VZE - Codes 25 + 26, pinging
- 2nd Gen Panhard (track bar) bolt question
- Problem with 86 carburetor
- Las Vegas!!!! Where you at??!
- Aisin hub replacement
- My new gas saver!
- 95 4runner shift issue maybe
- Seat Interchangability
- brake light, ebrake, freezing, etc ? diagnosis?
- Beck/Arnley vs Moog
- Hood scoop finally ready?
- 1993 4runner noise
- Shattered cran sprocket
- Alternator went up in flames... got a couple questions.
- Charging problems new alternator checked fuse
- 92 Toyota Pickup Timing Chain off 15 deg?
- Emergency brake equalizer
- Oil leak 5 months after changing valve cover gasket?
- Starter solenoid signal wire
- 1991 4runner 3l v6, burning oil... I think
- No Start! Key in, click, no crank. Help me diagnose wiring/starter. Contacts replaced
- My first Engine Rebuild Few questions...
- Steering turn radius question/issue SAS
- Yet another DRL install thread
- Vacuum leak??
- Need Emergency Help! Where drain plug goes?
- 87 Truck knock sensor missing
- Greasable shackles- hype? safe? worth it?
- Fuel Pump hose goes?
- BJ spacers Aligntment
- MSD 6A box run on
- Transmission sticks
- Oil Pan Gasket FIPG or Cork?
- greasing lower balljoint
- Quick Tip for your Dipstick
- '96 Land Cruiser e-locker into 2nd gen 8" diff?
- hole in muffler
- crazy loud intake
- Pulled the trigger!
- Add a leaf or new springs?
- changing rear brakes w/o parking brake?
- 88 Single Cab 4X4 "QUESTION"
- About to pull the trigger on an 88 ex cab
- 3.0 Vacuum Diagram anybody
- looking for a lil clarification wheel bearing torque...
- 92 v6 auto problems
- Upgraded Horn to Hella Supertones - Before/After Video
- 86 Runner Light Wiring
- 86 4runner tailgate trim removal
- Remote unlock FOB redux
- Unhooked speedo got code 42,43
- 88 Automatic Shift Problems
- 4runner 3vze will run briefly.
- charge for a carburetor rebuild
- Help needed with 88 Xtra Cab 3.0
- New 93 4Runner owner
- 94 runner part identification
- 93 4runner power steering issues
- Good trust worthy Mechanic for toyota 1989 4x4 Truck in Kettering/Dayton Ohio
- Vibration After Rear Wheel Bearing Job
- Idle Acting Strange
- New 4runner
- Weird acting temp gauge
- 1990 4runner 3.0L idles at 2800 rpms HELP
- '92 Pickup Warning Buzzer Everytime I Open The Door?
- High NOx Problem Leads to EGR Questions
- Designing a 3VZ-E MAF Conversion…opinions please.
- 87 22re running lean, high nox, rough idle
- 1990 4Runner 3.0L 4X4 WON'T CRANK!
- Cast Ball Joint Spacers?
- 22RE overheated - head gasket replacement thread [lots of pics]
- 95 4 Runner 3.0 to 4.5 Engine swap?
- 86' A/C Clutch works only when jumped??
- Heat shield?
- ADDING rear heat on 1st gen
- Just picked up a new 90 4runner
- Where do these go
- New to yotatech. 1993 4runner
- Yellow hardened Foam off side of block?
- 94 Jeep 2 door Cherokee crawler or 86 toyota pickup crawler
- How much rear D-Shaft Compression do i need?
- thermal vacuum valve mod
- Questions about Trail Gear rear disc conversion
- zuk mod, what spring rate for carrying 500#?
- My first Toyota and first stick shift...
- After rebuild won't start!!!!!
- Heater relay bad?
- 95 4R hand bent brake lines made easy
- engine lost power but was still running? did it jump timing?
- Clutch pedal noise
- 1988 3.0 overheating
- need some help with my brakes please!!
- chunk out of my 3vze cam pulley
- Correction Piston Intallation??
- What Truck/SUV to Get?
- Want more power and maybe MPG's!
- No interior lights
- coolant leak, water pump pulley
- DIY headlight harness keeps blowing RH headlight fuse
- Rockford CV Boots
- help with my 4runner
- Quick Exhaust Question..
- Help me diagnose -deep moan in engine bay
- 3VZE 400rpm Idle
- lower bolts on the egr
- Replace 3rd gen CV's with 2nd Gen CV's ???
- 2nd gen flatbed conversion
- AFM Plug & Play
- Clutch Noise? Need help
- Should I fix my oil contaminated clutch, 3VZ-E
- Well well well.....
- Need help please. 94 22re no spark from coil
- Clutch line bracket location, 22re
- Engnbldr
- 4runner security - croatia
- can I accomplish this?
- 2nd Gen Tire Carrier on 1st Gen 4runner
- Help!!! Truck keeps cutting out!!! Really neeed help!!
- 22r to 22rt
- Intermittent grinding from front right :S
- looking for fuel filler recess for rust repair
- 87 pickup, starter not disengaging
- C clip found in Transmission
- How to flush coolant with new radiator
- TPS adjustment problem
- cant find the right lower rad hose
- 91 4Runner CEL 24 25 27
- 86Toyota truck dash lights fuse??
- 1989 22r won't start 1st start of the day
- Anyone with OME Rear 2" lift springs?
- 1st Gen Wiper Arm to 2nd Gen Wiper Arm
- alignment issues after ball joint spacers
- My rear brakes lock up really easily
- Cherokee Coils on a 94 4ruuner
- Dropped bolt in thermostat coolant passage
- Starting issues click click click then maybe
- Brake light issues
- battery draining over night is this picture correct?
- Help With no start
- Newbie project. First post
- 87 Base Model gauge cluster conversion to SR5 Cluster questions
- Recommendations on LSPV/Panhard length with OME 900 lift? '95 runner, 31's
- After rebuild start up question
- Clutch Valve Question
- Quick question on ujoints
- 22rec timing question
- Part number for Factory Hood Deflector?
- 22RE stalling at operating temp, no OBD code or CEL
- What all would you replace from WRECK
- 22RE - Timing Bolt Chart (LCE)
- Intake mainifold or head gasket
- 22re Cutting out!! Driving me nuts
- Starter Clicks WTH?!?!
- 92 to 93 3.0 swap and now no start!!
- body work anyone??
- Trailmaster Dual Steering Stabilizer Ket: Is it any good?
- 22RE Fuel/Air delivery component impacted by temperature
- TPS worries...voltage and resistor, WOT V ?
- coolant temp gauge no more than an on/off switch?
- 4WD light on, No 4WD
- 3vze timing issue
- Where do these brackets go?
- Won't shift or start all of a sudden.
- I'm in the U.S and Desperately Want an 89-95 Double Cab 4x4
- Tranny Issues, Did I Over Fill It?
- runs rich at random
- 1993 4Runner A340H Auto wont move in Drive or Reverse (More Info Inside)
- 22re WON'T START
- Help Needed !! 91 22re idle issues
- Yukon Locker
- 93 toyota 4x4 pickup 3.0 l v6 NO Spark
- with stock leaf springs, do you get wheel hop?
- First problem I can't fix with a hammer.
- Another engine oil issue
- 86 Truck, shifters stuck in 1st and 4 low??
- Leaking from front
- Considering buying a 94 P/U with a 3.0 - is this photo a No-No?
- 22re glowing red exhaust header after first start up
- 3VZE Sensor ID help
- Transmission temp question
- 88 4x4 tranny flush (through the top ? )
- 1 Ton 1989 Truck Axle
- Warped valve covers on my 3vze
- ignition problem
- 22re problems
- Help broke down while mudding
- 94 3.0, low oil pressure and tapping noise...
- Two tiny things that you have to do to your old truck.
- Rear LSD worn and not doing its job - what to do?
- 4Runner - 5.29`s & 32`s messing with the Auto Tranny?
- new here!!
- gonna get yelled at, but I need help with lift options
- yota 3.0 timing issue (jumping the diag plug)
- Loss of power & noise during decel
- Wheel backspacing 1994 Toyota Truck
- 1993 Toyota 4x4 not pumping any fuel. HELP
- 87 22re a340h...will a 92 v6 a340h fit?!?
- Amsoil MTG GL-4
- rough starting 22re
- manual hubs
- 86 ignition wont lock.
- 92 3vze bucks when pressing the gas pedal slightly
- 95' Toyota 4runner studdering problem.
- Tranny is feeling stiff since fluid change
- Wiring issues
- 1987 Pickup 22R Intermittent Starter Problem
- Ignition set - Help?
- Funky SR5 Instrument Cluster Fuel Gauge
- front third member bearings
- 700r4 speed sensor
- Idler arm replacement '94 22RE 4WD P/U
- Solid Axle Kits
- Help to identify a support bracket
- Tail light innerchangability
- Not a Tech Issue, but awesome anyway
- problems with 22re
- Passenger front side. Horrible grinding noise
