Aisin hub replacement
Old Oct 21, 2012 | 10:40 PM
Edionne13's Avatar
So I bought an aisin hub just cause I messed with the spring about 3 months ago. Blah blah, this week I got around to get a used one off eBay. Took it apart greased my one on my 93 ext pickup painted it black on the rim an dark blue on the dial but now after a day of being on my pickup. One will not turn... I used spray paint bad idea? An can someone give me a link on how to reassemble the aisin hub the spring an stuff. Would greatly appreciate that ^__^
Old Oct 21, 2012 | 11:10 PM
wyoming9's Avatar
Talking
If you painted the plastic part and the part it rides in the paint dried and kinda glued it solid and keeps it from turning.
Old Oct 22, 2012 | 04:56 AM
waskillywabbit's Avatar
Amazing the things you will find if you search a little.
http://www.se4rj.com/forum/forumdisplay.php?f=19
:wabbit2:
Old Oct 22, 2012 | 04:47 PM
Edionne13's Avatar
:wabbit2:
Thanks for the link ill assemble that this Friday an yeah the paint kept it from turn grabbed a pliers and cranked it. Turned ill post pic of my truck probably once I get around to it. 4 inch suspension 112k original miles. 1993 ex cab 2 nd owner got a 3 inch body waiting for me in the garage. Running 33's look bad with the 7 in ifs lift?
Old Oct 24, 2012 | 08:36 PM
Edionne13's Avatar
well I got a friend who owns the same year pickup I do just sas and he says I need to use more grease. His you barely have to use any force is this normal? Yes his 4wd does work.
Old Oct 25, 2012 | 04:18 AM
Assembled correctly light grease they turn effortlessly. More grease piled in there actually hinders turning.
:wabbit2:
Old Oct 25, 2012 | 08:09 AM
jerry507's Avatar
I just reassembled mine a week or two ago and ran into an issue. If you've put it back together and can turn it freely only a very small amount, then you've put it back together wrong. Pay close attention starting at post #7 here:
http://www.se4rj.com/forum/showthread.php?t=293
If you do it wrong then it's put back in in the locked position but the dial is in the free position, and the mechanism binds up trying to pull it back.
Old Oct 25, 2012 | 09:17 AM
Luvmeye22re's Avatar
I wouldn't bother with the body lift, and yes it will look goofy with that much lift and 33's. That truck should be able to run 35's with minimal trimming as it sits.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
