greasing lower balljoint
Old Oct 19, 2012 | 10:52 AM
Fierce Legend's Avatar
I just did the front end of the ISF with some balljoints off ebay that look like the originals and all new poly bushings for the upper and lower control arms.
I installed everything before greasing the balljoints and was wondering how I can grease the lower balljoint with it in there? Can I use a grease gun with a tip that has 90%? or do I have to replace the fitting on the balljoint with an angled one?
I gotta split the lower balljoint to grease it?
Old Oct 19, 2012 | 11:27 AM
MudHippy's Avatar
The OEM ball joints don't even come with a zerk(grease) fitting. They have a small bolt capping the hole where it would go. Once the bolt is removed, you can screw whatever angle zerk fitting you choose(0°, 45°, 90°) into the hole. Making it easier(and/or possible with whichever type of grease gun tip you're using) to grease the ball joint while it's installed on the vehicle.
Old Oct 19, 2012 | 06:47 PM
Luvmeye22re's Avatar
My moogs came with 45 degree zerks, i got them oriented just right so I can get the flexible hose on my grease gun in there.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Scotttekoch
Sep 28, 2015 10:30 PM
