Oil Pan Gasket FIPG or Cork?
Old Oct 19, 2012 | 03:03 PM
badbob94's Avatar
Hey guys quick question
Puttn my 3.0 back together.
FSM says to use FIPG for the oil pan baffle and oil pan gasket.
However my master kit came with TWO cork gaskets for the oil pan and baffle.
Should I use Black High Temp FIPG or the cork, or a combination of both?
thx
Badbob
Old Oct 19, 2012 | 03:20 PM
vasinvictor's Avatar
FIPG, no doubt. Use a bunch, finger tighten the bolts, wait 20 mins, torque to spec. Never use both.
Old Oct 19, 2012 | 05:32 PM
scope103's Avatar
FIPG is characterized by VERY fast set time (as vasinvictor says, after 20 min it's been done for 15 min). Good if you're charging by the hour, not as good if you're a hacker like me. I prefer RTV, which gives me a little more time to work. You need to let it set overnight, but I've got time.
I have had good success with cork gaskets, but as vasinvictor says, make a choice. Don't use both.
Old Oct 19, 2012 | 05:46 PM
iamsuperbleeder's Avatar
good point... did that to the oil pan on my 22re once... that, didn't go so well...
Old Oct 19, 2012 | 06:00 PM
Rollon's Avatar
I used Permatex Ultra Grey. Put it on the pan and inststalled. No leaks.
Old Oct 19, 2012 | 06:05 PM
BigBluePile's Avatar
Fipg.
Old Oct 19, 2012 | 08:58 PM
rokblok's Avatar
Ditto. Ultra grey or Ultra black. Never had a leak when I have used either one.
Old Oct 20, 2012 | 12:07 AM
TNRabbit's Avatar
You'll never get the pan on with gaskets; the bolts are too short. Definitely FIPG or a reasonable alternative.
Old Oct 20, 2012 | 05:59 AM
badbob94's Avatar
Awesome guys, thanks for the quick reply.
Got a tube of ultra black for the oil pump and rear seal retainer so I'm good to go today.
Anybody need some cork gaskets??
Badbob
Old Oct 20, 2012 | 06:23 AM
MudHippy's Avatar
Earlier 3VZ-Es have longer bolts/studs to accomodate the cork gaskets. Later 3VZ-Es have the short bolts/studs that prohibit the use of the cork gaskets. I don't know which years have what(but my 88 has the longer bolts/studs).
Seems like we've had this conversation before. Maybe because we have.
Old Oct 20, 2012 | 08:52 AM
badbob94's Avatar
Funny thing the FSM shows the rear seal retainer being sealed using FIPG but the exploaded diagram shows an actual felt gasket.
My kit came with a felt gasket.
Which one should I have useD. I already used FIPG.
Thx.
Badbob
Old Oct 20, 2012 | 01:15 PM
MudHippy's Avatar
Originally Posted by badbob94
...but the exploaded diagram shows an actual felt gasket.
It does? Which diagram, where?
Felt? Are you sure about that? The only ones I've seen are the "paper" type.
Either one. FIPG is perfectly fine.
Old Oct 24, 2012 | 10:24 PM
ilovelivinginthecity's Avatar
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
