3.0 Vacuum Diagram anybody
Old Oct 18, 2012 | 04:35 PM
rc14's Avatar
I have a 90 3.0 and the throttle body has only three vacuum lines on top and no diaphram at the TPS like the 95 does. The 95 is like new and would like to use it
but can't find a good layout of the vacuum lines for it. It's like three more lines coming out of the new one. I have done a search but no luck.
Thanks
Roger
Old Oct 18, 2012 | 07:28 PM
Punchy's Avatar
Pretty universal for 87-95 V6.
http://personal.utulsa.edu/~nathan-b...74layoutan.pdf
Old Oct 19, 2012 | 10:44 AM
rc14's Avatar
Punchy
that's a good one for the 90 model but the 95 is the one i needs.
Thanks
Roger
Old Oct 19, 2012 | 12:23 PM
ksti's Avatar
Could you take a couple of different angle pic's of both TB's side by side?. Something just seems weird. I'm pretty sure that the motor was changed from a 3.0 (3vze) to a 3.4 (5vz-fe) in mid 95.
EDIT: After some thought I'm thinking it's probably different because of manual or automatic transmission and if it has cruise control or not.
Old Oct 20, 2012 | 05:17 AM
rc14's Avatar
I will try to get some pictures but i have not been able to upload pictures.
Old Oct 20, 2012 | 08:17 AM
brianh699's Avatar
can't you just switch the throttle bodies use the one off of the 90 motor?
Old Oct 20, 2012 | 08:24 AM
ksti's Avatar
He's asking if he can use the 95 throttle body assembly as he states it's newer.
Old Mar 16, 2014 | 12:37 AM
redneck2240's Avatar
I just did the same to my 90 runner since the idle air valve was shot. It will work as long as you hook the right lines up where the old ones hooked up and you may have to plug off an extra port if not already done
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
montanatruck
Feb 26, 2017 07:07 AM
gmonnie123
Jul 26, 2015 02:44 PM
Poppie51
Jul 23, 2015 05:03 PM
TokyoD23
Jul 12, 2015 06:01 AM
