Weird acting temp gauge
Old Oct 16, 2012 | 06:24 PM
lilgription's Avatar
Question Weird acting temp gauge
Ok. I have a gremlin ..lol. 90 model truck. Sr5 22re. In the mornings with the heat on and the vent switch set on the fresh air mode my temp hand starts to climb quickly above normal. The instant. And I mean almost instantly when I switch to recirculates or even the half and half position the hand falls to normal in the blink of an eye. Ive had Toyotas for 20 years and never had this happen before. Any idea what may be causing this. I guess I should include that I have the temp gauge that goes from C to H
Old Oct 16, 2012 | 07:09 PM
timothy47129's Avatar
Easy test for the gauge take the wire off it and touch it to a good ground with the key on and your gauge should go all the way to h when its grounded and back to c when you remove the ground.
Old Oct 16, 2012 | 07:32 PM
brianh699's Avatar
Possibly an intermittent short to ground. Moving the recirc lever moves the wire? Check the wiring for continuity to ground either on the back of the gauge, or the sensor wire.
Old Oct 17, 2012 | 04:09 AM
I'll try and test the gauge this eve. I had thought about throwing an after market gauge in anyway
MadMax48
Mar 3, 2020 10:33 AM
imhousing
Sep 10, 2015 02:04 PM
LucasF249
Sep 8, 2015 01:17 PM
--Oz--
Sep 6, 2015 01:06 AM
