PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 93 4runner, back fires through the intake when cold
  2. 1993 Toyota Pickup Shocks
  3. 22RE passenger side timing chain guide clack
  4. 94 Toyota Front parking brake cable
  5. Trick/tool to remove hidden intake manifold allen bolt?
  6. 89-95 pickup jack and spare tire tools kit.
  7. power steering mysteriously not working anymore
  8. Divorced downpipe
  9. 94 4runner 3.0 3vze missfire & more
  10. 86 toyota pickup Starting Problem
  11. Top alternator bracket bolt?
  12. Code 13
  13. Warm idle issue
  14. About to purchase an 88 4Runner
  15. Transfer Case Leak
  16. 4.56 or 4.88?
  17. #1 spark plug pic (what could cause this?)
  18. Hi-Lift Jack (w/wheel attachment) on stock Toyota rims?
  19. How many miles/years do you have on your orig 22RE fuel pump?
  20. Suspension!!
  21. Wiring GM alternator to 22re?
  22. 3VZE heal thyself!
  23. 50 mph at 3000 rmp related to Code 71
  24. T4R first gen - Hard top reinforcement for a roof tent
  25. 1992 4Runner, New TPS, New Alt. Brushes Car won’t start
  26. Been searching... efi relay quagmire...
  27. Hestitation/VSV/Idle Timing all related Issues?
  28. Ignition switch woes after purchasing a replacement...please help!!
  29. fuel filter
  30. Fox Suspension?
  31. Power steering problem
  32. Installing Idle Up on 3vze
  33. Oil Problem or no ?
  34. New rebuilt no start throwing codes 7 and 11
  35. New Injectors, NO START!?!
  36. 94 3vz Timing is off?
  37. 1988 22re 4x4 W56 Build. (For Real This Time)
  38. Worn CV or Diff?
  39. Need help with Wiring Harness Connector 86 4runner DLX
  40. 91 3.0 idle
  41. 94-95 22re toyota a/c lines?
  42. 95 4runner 3rz FSM Amazing but
  43. NEW HG overheating Specific Question
  44. 1987 4runner rough idle on cold start/no power
  45. Brake Pedal Binding
  46. Changed brake booster - Won't start now
  47. Igniter part number for a 1985 T4R 22re motor
  48. New old pump priming question
  49. First Post: A few questions
  50. Fuel Pressure Damper Screw
  51. Toyota v6 - 3vze or other?
  52. Transmission and Transfer CASE same ?
  53. Center console - spare cables
  54. 1995 4Runner 4wd will not engage.
  55. Erik's Toyota Differential Website (Clarifying Question)
  56. Need help W/ oil pan pls :D
  57. Loud radiator fan.
  58. Emergency Brake will not completely disengage leaving light on instrument cluster.
  59. Another Neutral Saftey Switch Post
  60. Power Steering pump issue HELP!
  61. 87 aisin carb power valve
  62. Shocks for lifted 2wd
  63. Hose number?
  64. Help please
  65. weber carb help
  66. 22RE rough idle...the journey
  67. 91 pickup 22RE oil pan gasket?
  68. 1990 4runner injectors- compatibility q
  69. Lifting 2wd
  70. 1993 Toyota T-100 Misc Info
  71. 22rte header
  72. Weber with LCE adapter now guzzling gas but running fine
  73. 1987 Toyota pickup problems
  74. Intermittently loosing Power Steering
  75. Newbie Wheel Question
  76. 89 pickup 22re 4x4 ain’t crank.
  77. Clutch slave working but clutch won't disengage.
  78. 89 4runner Help alternator?
  79. engnbldr 268c Torkr valve lash from Ted
  80. Idle Car problem
  81. Low inital idle 3vze
  82. Timing chain cover & water pump gaskets go on dry?
  83. Need help choosing shocks for 95 4runner
  84. What is a good 22RE timing chain guide?
  85. 1989 4runner 4" Trail Gear Sas and 63s....advice for leveling
  86. 3vze 5 speed swap issue! A/T oil temp light
  87. 1994 2.4L Automatic Hilux
  88. Lite click from driver front wheel
  89. AC only blows cold at max setting
  90. 92, LN130, 3VZE, Bluetooth/Android... OBD1?
  91. Better than they were (badges)
  92. fuel pump location
  93. Cranking no start after o2 sensor repair, lost fuel/spark
  94. Heavy duty offroad front bumper
  95. transmission identification
  96. 32x11.50s rub A-Arms with 1.5” BJ Spacer, OME T-Bars, Stock SR5 Wheels
  97. please help me finding parts for my 94 22re pickup
  98. 1986 4Runner: Replacement mirrors
  99. Power steering pump issue
  100. Going To Give Up On The 3VZE
  101. 3vze header install; heat management questions
  102. schematic for 1994 4runner rear window control
  103. Spark Plugs and Wires
  104. fuel prob
  105. Aisin clutch kit confusion via Amazon
  106. T4R first gen - Add USB/Aux adapter to OEM radio
  107. HELP setting Cam Sprocket to TDC
  108. What is the Gasket/Seal for the steering shaft through firewall?
  109. Best fitting seat covers ?
  110. Searching for seat cloth
  111. Can i swap rearends in a 92 and 97 4runner?
  112. 87 4Runner no start after elevation change
  113. '95 4Runner 3.0 coolant leak
  114. 93 4WD odometer cable?
  115. Cyclical misfire out of nowhere
  116. Parking brake affects alternator!?
  117. Missing connectors/vacuum tube 22RE/91 Pickup
  118. Throttle Cable
  119. 22r weber help needed
  120. 94 4wd 4runner
  121. Knock Sensor
  122. 3vze compatability questions
  123. 86 pickup radiator recommendations
  124. 22re problems??
  125. Please help 95 4runner 3.0
  126. Tranny interchangeable?
  127. 22RE Help Please
  128. 3Vze Injector Plugs Crumbling to Pieces
  129. Another Conversion: My '90 V6 truck gets an LT1 V8
  130. 3.0 to 4.7 swap
  131. How do I hook up VSV in 3.0?
  132. Video - Loss of power on acceleration - Bad valve body?
  133. Where to buy a replacement 1986 gas pick up tube for carburated engine?
  134. 86 Toyota pickup not starting!!!!! Does one click when I turn the key
  135. Brake pedal hard to depress '95 4Runner
  136. 94 22re knock sensor wiring
  137. 91 front bumper -> newer style
  138. Window Switch Woes
  139. Codes 12, 41, 51, 52- 3VZE
  140. 3vze overheating water slushing sound
  141. Should be 12v, but reading 4.94v? Testing ECT ECU 87 4Runner 22RE-T w/auto
  142. no start 1994 camry v6 xle
  143. '87 4runner 22RE rough idle when starting.
  144. Attaching the Window to a Window Regulator
  145. Penguin's 1987 4Runner SR5 Build Thread
  146. Checking ball joints 94 pickup 2wd
  147. Vibration when letting off gas at speed after OME 2.5" Lift
  148. 1993pu 3vz timing issue
  149. Runs rough at idle dies then won’t start
  150. Pic of '94 Tailgate Window switch harness
  151. 4runner mirrors on a 94 pickup
  152. 86 Pickup Vent Window
  153. 1994 v6 pickup dash lights and taillights wont turn on
  154. 86 Toyota pickup vapor canister
  155. 86 Toyota pickup vapor canister leaking fuel
  156. Timing Chain - remove head?
  157. I think carb problems
  158. AC install on 93 pickup
  159. 88 4runner manual hub swap help
  160. 86 4runner caliper upgrade
  161. code 25 - running lean or at least reporting lean
  162. Install aftermarket radio into a 1986 Toyota pickup no speaker sound. Please help?
  163. Can't get hub reattached to upper ball joint?
  164. Throttle cam rebound dampening
  165. Replacement fuel tank failure
  166. Brake master cylinder
  167. Wheel question
  168. 3vze leaking bad
  169. Monitor OBD-1 Data stream
  170. 94 toyota pickup 22re
  171. Combination Meter aka Dash Gauges aka Cluster 22R-E
  172. Dash Illumination (backlight)
  173. A/C Issues
  174. snorkel instal
  175. Best place for Used 1st Gen 4Runner Parts
  176. 1992 3vze idles issue
  177. skid plate and grill bar
  178. 2in lift front
  179. SAS swap with FROR Brake kit rotor queston
  180. Electrical Gemlin
  181. Roughly 75% power loss and metallic slapping noise
  182. 92 Pickup A/C idle Up
  183. Lights Reversed
  184. 95 4Runner Not Starting - has spark/fuel/air
  185. Front/rear diff and transfer case plug sizes?
  186. Vacuum line question
  187. Bulbs for Rear Switches? ‘87 SR5 1st Gen 4Runner
  188. Fuel pump bypas
  189. Push Bar mounting??
  190. now that engnbldr is out of action. who is the best for cam/head/timing chain/oilpmp
  191. Coolant Flush Parts
  192. Hitch rating?
  193. toyota celica gt 1981 A/c problems
  194. Help identifying stepside bed for Toyota
  195. 22r Belt tensioner bolt size and pitch
  196. Low idle
  197. Back Up switch - too short
  198. Help with coolant leak on manifold union 3vze pickup when engine is off
  199. 4Runner window trouble
  200. Weird Overheating Problem
  201. 86 xtracab seats and rear shelf
  202. dome light part
  203. 86 2wd Xtra can body on 86 4x4 single cab
  204. Special tools for rotors and ball joint swap '94 runner?
  205. Recovery Points (Pointers Needed)
  206. Mounting Shovel & Hi-Lift Jack?
  207. Stock Temperature gauge reading slightly above 1/2
  208. what kind of obd11 scanner do i need for my 1996 toyota hilux surf 4runner.
  209. Does anybody here have a SunTop or even good pictures of them?
  210. Replacement of A/C Idle-Up Actuator on 87 4Runner
  211. AC evaporator 87 Toy
  212. CEL on and not sure what it is
  213. Frame repair integrity question
  214. 1990 22re 2wd manual transmission speedometer cable ?
  215. 1990 22re 2wd Oil pressure sensor wire ?
  216. 94 pickup 2.4L tow question
  217. Weber carb
  218. Welcome (back) home 94 pickup
  219. RF1A Transfer case bearing numbers
  220. solenoides
  221. CCA needed to start a '87 22R
  222. My clutch is acting wierd
  223. Black Sludge in top of Carb and in intake manifold 22R
  224. Truck Weight for Recovery Strap
  225. '87 won't start when hot
  226. 3VZ-e won't start without gas pedal pressed
  227. Recovery Points on my '94?
  228. 94 Pick 2.4L No Speedo or Temp Gauge
  229. 93 4runner oil 'problem'(?)
  230. what gear oil to use 80/90 ?
  231. AC idle up help
  232. Help with location of 3vze coolant drain plug
  233. How Charging System Works - 22RE
  234. 3rd Member Slop
  235. 22re code 25, but runs perfectly
  236. First Yota, Strange 4wd issue
  237. 93 Pickup What year auto trans will fit
  238. Surging idle question
  239. Best source for transmission gears?
  240. Standalone install 1990 4runner 4x4 turbo 22re
  241. 90 4runner factory service
  242. Aftermarket Seat Recommendation?
  243. Horn Relay Retrofit for First-Gen 4Runners
  244. cat delete?
  245. Repairing corrosion in engine block coolant passages?
  246. 3.0 rebuild begins
  247. Proper jacking point for factory bottle jack on an '88
  248. Reminder: time your 22r properly!
  249. RR crossing conked out my 86 4runner
  250. alt fuse
