22r weber help needed
Old Jul 25, 2018 | 11:25 AM
Coldcdn's Avatar
Hi all need some input on my weber, it's a 32/36 useing the lce spiral adapter to stock manifold on a 22r in a 1987 4x4. So I am running into a no power issue at higher rpm in 4th and 5th as in pedal to floor more exhaust noise but sadly no pull or power?. What I am I missing thanks
Old Jul 25, 2018 | 02:03 PM
L5wolvesf's Avatar
How long has it been in the truck?
How long have you had the problem?
What did you do when you were tuning it after installation?
Where are you elevation wise?
Do you have a fuel pressure regulator?
Your location is helpful so it would help if you had it in your profile. And, put your vehicle info on you
Old Jul 25, 2018 | 03:28 PM
Coldcdn's Avatar
It's been in the truck for about a week with new lce adapter
yes I have fuel reg and fuel pressure guage currently set to 3psi
set timing to 5 degrees and advance
followed redline tuning procedure
fuel idle is screwed out 2 turns
Fast idile screwed in13/4
located Vancouver bc canada so sea level
the truck itself is a 1984 4 x 4 reg cab long box 5-speed with 22R power plant. Did call Redline asked them they suggested adavanceing the timing a bit and see how it feels
Old Jul 25, 2018 | 04:06 PM
L5wolvesf's Avatar
I'm getting a picture of the situation . . .
One reason we like the vehicle info in the signature line is it doesn't go back in time unexpectedly. Put whichever vehicle info you are working on there so people here can help.
One other question - have you made any modifications, besides the Weber, to whichever truck you have?
Old Jul 25, 2018 | 05:05 PM
Coldcdn's Avatar
It's a 87 and desmogged when I put weber on.Sorry for the misprint
Old Jul 26, 2018 | 05:44 AM
se7enine's Avatar
When you say "higher RPM's" what do you mean? In the 3-4K? 4-5K? Were you doing these higher RPM's before the Weber? A Weber isn't a turbo so don't expect much in terms of more power, especially if no further engine mods have been done.
Old Jul 26, 2018 | 08:08 AM
Melrose 4r's Avatar
5 Year Member
confirm full throttle opening by having someone else operate the throttle while you look(engine off)
look for any unplugged vac tubes, possibly off the secondary barrel.
Old Jul 26, 2018 | 09:06 AM
Coldcdn's Avatar
Higher rpm is 2000-3000 rpm by hwy spd avout 90km/hr and yes Its much drive to work. Will check for full opening thanks
Old Jul 28, 2018 | 01:19 PM
superex87's Avatar
Along with the other suggestions here, ditch that fuel regulator. I used the same one a while back and it does not work right. I purchased a Holley regulator and never had problems with it after that. It seemed to not be supplying enough gpm to keep up the weber.
yotaholik
Feb 9, 2015 08:07 AM
1st Gen Crawler
Jan 13, 2015 04:36 PM
Hurakane
Dec 14, 2012 05:12 AM
AustinTaco
Jun 22, 2010 06:40 AM
