NEW HG overheating Specific Question
Old Aug 17, 2018 | 08:43 AM
rbNW's Avatar
I have read almost of the threads I can find on the topic...
I installed new FelPro HG on my 92 4runner. I am 99% sure I put them on the correct way, BUT, I keep overheating with the T-Stat installed.
If I take the T-stat out I run slightly below normal temps and the top and bottom radiator hoses are the same luke warm temp, which I believe means I have coolant flowing through the system.
I took the top radiator hose off, and blew into the radiator and coolant came gushing out the top hose from the engine, which I THINK means that the HG must be installed correctly.
QUESTION: IF I have coolant flowing both directions through the engine does that mean the HG is installed correctly?
I also used a hose and shot water into the top radiator hose and water came out the bottom hose, so I don't think there is a block in the engine.
When I drive with the T-stat installed the bottom hose stays ice cold and the top hose is VERY hot. When I drive with the T-stat out the bottom hose also gets hot, which I again, think means the HG is installed correctly.
I think the PO used some sort of stop leak crap in the radiator before I bought it.
I have burped the coolant system by parking on a steep hill and turned the heater on full blast.
Here is what I have done:
New Radiator, New Clutch Fan, New OEM T-Stat, new top and bottom rad hoses
Any idea what I should try next?
Thanks!
mtrdud
Jul 18, 2012 07:17 PM
gotime242
Mar 4, 2011 12:07 PM
blake.nemitz
Dec 6, 2010 10:46 AM
CoedNaked
Feb 7, 2005 10:27 PM
