alt fuse
Old Jun 24, 2018 | 04:26 PM
turpinr1's Avatar
alt fuse
97 dodge 2500 4x4 alt fuse keeps blowing. I have replaced alternator and battery yesterday
Old Jun 24, 2018 | 04:54 PM
Co_94_PU's Avatar
Something is wrong with the feedback circuit, or you've added accessories that are pulling to much current.
If it's the last problem nothing to be done but pull them off and fix your implementation..
First one could be tricky, but start with making sure all the connectors are clean and tight. Bright shining metal to bright shining metal.
Old Jun 24, 2018 | 05:28 PM
slow-mo's Avatar
Even though your post is not about a Toyota, when I replaced my alternator in my '87 truck, the new alternator was bad right out of the box. I bought it from Autozone. It also would blow the fuse immediately when reconnecting the battery. I eventually used my DMM to verify that there was continuity between the alternator battery wire and the body of the alternator.
I took it back to Autozone, they tested it, and yep, it was bad. I install the replacement, and this one worked correctly.
Old Jun 24, 2018 | 06:04 PM
Terrys87's Avatar
I too have gotten rebuilt alternators right out of the box that were bad. I would have it checked out to make sure you do have a good alternator. Most electrical issues I find are from wiring being hacked or after market equipment being added. I suggest disconnecting non factory components and see if you still have issues.
Old Jun 24, 2018 | 06:12 PM
RAD4Runner's Avatar
Originally Posted by slow-mo
... I eventually used my DMM to verify that there was continuity between the alternator battery wire and the body of the alternator...
Yes. A bad rectifier could do that.
O.P.,
Disconnect alt-to batt wire from stud terminal of alternator. Measure resistance from stud terminal to bright, shiny metal of battery negative or body ground like Slo-Mo did^^^. You should get LOTS OF Mega-ohms. If not, yes, bad alternator.
Old Jun 24, 2018 | 09:50 PM
wyoming9's Avatar
Red face
The quality of Rebuilds has declined and keeps getting worse!!
Best thing is find a local Auto Electrical rebuilder
Old Jun 24, 2018 | 11:29 PM
RAD4Runner's Avatar
Why were the "alternator and battery" replaced?
Did the blowing alt fuse prompt replacement of alternator & battery, OR did replacement of alt and batt cause the alt fuse to blow?
greyheadedguy
May 16, 2019 01:16 PM
se7enine
Aug 21, 2017 02:55 AM
sharkuttack
Jul 12, 2017 05:59 AM
eutahg
May 8, 2017 05:40 PM
deadrunner
10
Oct 21, 2003 06:40 AM
